Mitsubishi Evo4-EvoX and Subaru EvoScan Datalogging Project
Postby hexman » Mon Nov 27, 2006 6:14 am
You should post on active matrix or evolutionm.net. I don't know how often Malibu Jack goes to this forum.
hexman
Postby speed kills » Sat Dec 09, 2006 8:30 pm
So evoscan 0.98 is out, are we going to get it any time soon by e-mail. Because on your site it says it's been out.
speed kills
Postby laakness » Sat Dec 09, 2006 11:03 pm
What part of the following are you not understanding as far as timing?
December 2006 - EvoScan v0.98 version - not yet released - coming for xmas :)
laakness
Postby speed kills » Sun Dec 10, 2006 7:18 am
That was changed after my post. It never said after X-mas. Nice way of putting people down.
speed kills
Postby Travis » Wed Jan 03, 2007 6:42 pm
after xmas and I have no email. was it sent?
Travis
Postby Fitz » Wed Jan 03, 2007 6:55 pm
3gturbo wrote:
laakness wrote:Evoscan will read in the serial data that your Wideband is sending it. Do you have the XD gauge hooked up, because by default THAT has a max of 20.9 on it, so if it goes out of range it will display that and the word o2 repeating...just a guess.
I have the lm-1 inputting into my e-01 and display the data there it never goes over 20.9. What I suspect is happening is when I let off the gas instead of evoscan logging the 20.9 reading displayed on my screen it logs erroneous data in the 80-120:1 afr range so when you open a data log it scales the left side to the highest data logged. When your trying to look at a range of 3-4 afr jumping to 120 makes your log a straight line which makes it alot harder to see the afr.
That makes sense, each data sample from an LC-1 is basically four bytes (there is also a header and length, but that is for the encompassing packet). The top word is status, the bottom word is a value. The meaning of value depends on status. Lambda, the value is 0-1023, with each count representing .001 lambda and an assumed offset of .5 lambda (so the range is .5 to 1.523), O2, the value is pressure, Error, the value is an error code, warmup, the value is percentage complete, and so on.
If the software treats all values as lambda, regardless of status, you would get some very weird readings in other states.
Another possibility is the the AFR multiplier programmed into the LC-1 is incorrect. All readings are in lambda, so to convert to AFR an application multiplies the lambda value by the AFR multiplier (typically 14.7 for gasoline). If the software is honoring the muliplier in the packet, and it is wrong for the fuel used, then you'll get weird readings as well.
-jjf
Fitz
Postby Evo4Mad » Wed Jan 03, 2007 10:22 pm
yeah you are right, I am treating them all as lambda, ignoring the status packet.
you have to remember your display isn't always showing AFR it switches to % oxygen (20.9) which relatively = 80-120 AFR which means lots of oxygen
Postby goosey2099 » Fri Feb 09, 2007 6:03 am
How is the progress comming along? How long until the final release?
goosey2099
Postby C6ect.ect » Fri Feb 09, 2007 6:04 pm
Listen up everyone,
When Evo4Mad (or whoever it is making the product I enjoy more than beer and pain medication) is done with it he will email you and probably advertise on all the forums.
Just let him finish his project, through my experience in life, and I am an old ass fart, whenever you rush someone the product may be effected.
With that said, 4mad please take your time because right now I am really enjoying the v0.97
OK, time for insulting comments - bring them on computer wussies
C6ect.ect
Postby laakness » Fri Feb 09, 2007 6:20 pm
C6ect.ect wrote:Listen up everyone,
I actually agree. Evo4Mad has gotten us a very stable product so far. Future versions will only be addons/enhancements (which are welcome).
laakness
Postby goosey2099 » Sat Feb 17, 2007 1:57 pm
I hear ya, and i am in no way rushing anyone. I'm also a developer and i know that writing quality applications takes time. I was just asking, thats all.
goosey2099
Postby imprezarsx » Wed Feb 21, 2007 8:14 pm
I haven't recieved a single update in the mail. I have like .92 or something. I have sent an email asking for an update, but no response so far.
imprezarsx
Postby c-spec » Wed Feb 28, 2007 2:10 am
imprezarsx wrote:I haven't recieved a single update in the mail. I have like .92 or something. I have sent an email asking for an update, but no response so far.
+10000 same here :cry:
c-spec
Postby Evo4Mad » Fri Mar 02, 2007 2:29 am
I reply to everyones emails within 12-48hrs.. not sure why you would say no response within such a short time period?!
Postby c-spec » Sat Mar 03, 2007 10:52 pm
i got it. thanks evo4mad
c-spec
