Evo4Mad wrote:Sure thing [05Evo], just hook up your LC1 and external sensors, and log them to the csv file using v0.95 and send me the logs, and I can add external sensor logging support for these devices also. I think the LM1 I have can do external 0-5v sensors via this little black box and loads the readings back to the serial cable too, I just don't have any spare external sensors to hook up to it.
Check your Junk/Spam folder. Most people have had his email flagged as spam.Virdepax wrote:hey evo4mad I have 0.8 but I haven't recieved the update email yet.
Evo4Mad wrote:Hey guys, I've just about finished v0.96, here are the main features.
Update v0.96- Calculated data value feature added - calculated values can be based on other log items using their current value.
- Load added to the logs as a calculated data value.
- Gear added as a calculated data value - used for the dashboard view.
- Miles per gallon added as a calculated data value.
- KMs per Litre added as a calculated data value.
- GaugeFactor field added to data.xml - used for e.g. on the Rev counter gauge to display x1000rev/min
- State Indicators feature added to gauge windows
- Digital Gauges feature added to gauge windows
- Log Run Editor - specify the log file and start/end times for each run. first stage to being able to compare and view log runs in the new graphing being developed.
- Alarm Editor - allows criteria to be applied per data item logged, and a specific wav sound file to be played, any wav file from the \SoundFiles\ directory.
- Wideband serial port logging - used for debugging
-Innovate LC1 wideband logging support
Users browsing this forum: No registered users and 56 guests
