Mitsubishi Evo4-EvoX and Subaru EvoScan Datalogging Project
Postby MalibuJack » Mon Sep 25, 2006 10:23 am
Evo4Mad wrote:It works on some vehicles, not all.
1C 0.625x %
If the value works on a particular ECU, the max value 255, will read 159.375 Considering on my car the load is well over 260, this probably won't work well..
I'd hazard a guess that maximum also correlates to the maximum MAF reading before its clipped also..
In other words, its good for low boost applications back in the day when these algorithms were designed..
Its good to correlate low load data, especially if the calculated load value is not accurate due to closed loop fueling..
Makes me wonder why they didn't use two bytes for responses instead of one (obviously speed of logging may have been a concern, or even the overhead of using two bytes to represent data may not have been possible if the available ram was limited..)
MalibuJack
Postby rwunsche » Mon Sep 25, 2006 11:12 am
Gotcha. Sorry, I meant to put a smiley on that post! :wink:
rwunsche
Postby Evo4Mad » Mon Sep 25, 2006 12:22 pm
MalibuJack, there is normally two byte requests one for high byte and one for low byte.. it will become very obvious once I reverse engineer the evo8 ROM
Postby MalibuJack » Mon Sep 25, 2006 2:10 pm
Thats what I would think too.. It would seem logical that the high byte and low byte would be adjacent codes or some logical way to group them. Time will tell there's enough people working on the roms that its only a matter of time this info will get documented.
Definitely curious to what you guys come up with.
MalibuJack
Postby chrisw » Mon Sep 25, 2006 4:35 pm
Evo4Mad wrote:MalibuJack, there is normally two byte requests one for high byte and one for low byte.. it will become very obvious once I reverse engineer the evo8 ROM
I can't imagine that not being the case since it is a 16bit processer right?
Assuming it is a 2 byte value, I would expect the byte that we are using to rollover, but this is not the case...
something else is going on.
chrisw
Postby MalibuJack » Mon Sep 25, 2006 5:31 pm
According to Evo4Mad there are 10 different possible initializations.. Its entirely possible that there is a seperate mode that has 2 byte responses that either he's not talking about, or is currently unknown.
I am in the process of aquiring a MUT-III tool which should allow me to get quite a bit more useful information. Its entirely possible there is a MUT-II and MUT-III mode...
MalibuJack
Postby laakness » Wed Sep 27, 2006 4:29 pm
Evo4Mad...
Any chance on a release with innovative LC-1 support? Maybe you could put up a repository where people could download any of the versions...including the "in progress" builds so we could get you feedback quicker/during dev.
laakness
Postby AutoXer » Thu Sep 28, 2006 2:30 am
laakness wrote:Maybe you could put up a repository where people could download any of the versions...including the "in progress" builds so we could get you feedback quicker/during dev.
I really like that idea! You did say that adding the LC1 support would only take you ten minutes to code in.
AutoXer
Postby Evo4Mad » Thu Sep 28, 2006 2:33 am
I have 5 days off work to play with my Evo, shouldn't be a problem. ;)
Postby MalibuJack » Thu Sep 28, 2006 4:55 am
I'm Sympathetic to Mad4Evo's plight..
Keeping a current build available online is alot more work than you guys realize.. I generate a new build for my software every few hours and couldn't imagine packaging it every day and publishing a snapshot..
Give him a little bit of a break, not that you guys are giving him a hard time, but I'm sure he'll be getting something out.
I realize how much work it is to get this stuff together only in free time. It'll come soon enough.
MalibuJack
Postby laakness » Thu Sep 28, 2006 5:24 am
Evo4Mad wrote:I have 5 days off work to play with my Evo, shouldn't be a problem. ;)
Thanks.
laakness
Postby AutoXer » Thu Sep 28, 2006 6:05 am
***edited as requested***
AutoXer
Postby evoralph » Thu Sep 28, 2006 7:23 am
i love evo4mad :shock:
evoralph
Postby epifan » Thu Sep 28, 2006 7:47 am
edited :lol: :lol: :lol:
epifan
Postby Evo4Mad » Fri Sep 29, 2006 12:08 am
lc1 support added, yay :)
