A418t81 wrote:Logging my LC-1 through evoscan gives me AFRs in the 40s on idle. Logworks open at the same instance reads correctly.
NoQuarter wrote:A418t81 wrote:Logging my LC-1 through evoscan gives me AFRs in the 40s on idle. Logworks open at the same instance reads correctly.
If you mean you are reading the LC1 from both applications at the exact same time I don't think that will be possible. Both of those apps will not share the port at the same time.
A418t81 wrote:Curious that I am seeing 40.xxxx and everbody else here is basically seeing 20.
NoQuarter wrote:My LC-1 reading stays at 19.4 something also. It doesn't seem to change at all.
