Mitsubishi Evo4-EvoX and Subaru EvoScan Datalogging Project
Postby Evo4Mad » Sun Sep 10, 2006 4:00 am
http://limitless.co.nz/EvoScan/
Event Log :
Sunday 10th September 2006 - EvoScan v0.9 PreRelease version released.
By Default Logs are stored here:
C:\Program Files\EvoScan\EvoScan v0.9\SavedDataLogs\
Edit this XML file to change data item codes and calculations:
C:\Program Files\EvoScan\EvoScan v0.9\DataSettings\Data.xml
Data Logger Features: EvoScan v0.9
UPDATE:
1) Realtime Graphing support, mulitiple graph support, select data items.
2) Realtime playback of saved csv data log.
(even works without being plugged into the car!)
3) Create / Edit / Save / Load Gauge template xml files.
4) Drag, Drop, and Position any number of gauges onto the screen.
5) Assign data logging item to each gauge
6) Save/Load Gauge screen layouts/gauge config into a shareable xml file.
7) Simultaneous synced WideBand serialport meter Logging Support
- Innovate LM-1 Wideband support. (Tested as Working)
- Innovate LC-1 Wideband support. (Untested)
- AEM Uego wideband support. (Untested)
- Zeitronix Zt-2 Wideband support. (Untested)
8) Global HotKey Support.
9) Logging status colour indicator.
10) Added logger data items, Speed/Octane/AFRMap/MAP.
Data Logger Features: EvoScan v0.8
1) Increased Datalogging Speed!
- Added Log To File option
- Added Log To Screen option
- Added Logging SuperSpeed option
To get maximum speed - Disable Log To Screen, and Enable Logging Superspeed. Less effect is noticed on 2000ghz laptops with a/c power, but slower laptops or laptops running off the battery benefit a lot of speed!
2) Increased Stability of start/stop datalogger.
3) Added AYC Info to Data.xml
4) Added DTC Fault Code Info to Data.xml
5) New Log File Format! - Thanks for all of your feedback on this - results now cross-tabulated with easy to use LogId/Date/Time/Seconds
6) Altered DataItem Calculations:
- Increased accuracy on FuelTrim calcs. (Fuel Trims: <100% (lean) >100% (rich) )
- Fixed accuracy on Timing Adv calc.
- Added DataLog="Y" to xml file for default datalogging items ticked.
- Implemented Multiple ECUs to XML file.
7) Added DTC Trouble Code Support
- DataLog Active/Stored Fault Codes
- Retrieve EFI Fault Codes
- Clear EFI Fault Codes
Added simultaneous WideBand SerialPort Logging Support (untested)
9) Added View Log Files Menu Item
10) Added ABS Info to Data.xml
Register Now to Download EvoScan v0.9 - $25US
Postby turbocharged » Sun Sep 10, 2006 5:18 am
:o
turbocharged
Postby SilverBack » Sun Sep 10, 2006 5:19 am
Can we assume registered users will recieve an e-mail as before?
Once again - good work!
SilverBack
Postby Evo4Mad » Sun Sep 10, 2006 5:23 am
Currently registered v0.8 users will get v0.9 via email.
You can PM me directly any feedback, and keep this topic focused on program enhancements :) thanks.
Postby fixem2 » Sun Sep 10, 2006 6:40 am
Have the DTC codes been updated and can they be cleared?
fixem2
Postby A418t81 » Sun Sep 10, 2006 7:04 am
fixem2 wrote:Have the DTC codes been updated and can they be cleared?
I have .8 and never recieved an email...
A418t81
Postby Evo4Mad » Sun Sep 10, 2006 7:09 am
No they haven't I will look at these next time I review the MUTIII protocol again.
Postby Evo4Mad » Sun Sep 10, 2006 7:11 am
Emails will be sent tomorrow afternoon, I was upgrading the web hosting, the hosting company screwed it up, the domain name is down at the moment.
Postby A418t81 » Sun Sep 10, 2006 7:11 am
Evo4Mad wrote:Emails will be sent tomorrow afternoon, I was upgrading the web hosting, the hosting company screwed it up, the domain name is down at the moment.
I see, thanks again for your hard work.
A418t81
Postby danl » Sun Sep 10, 2006 9:46 am
Looks good if it all works as advertised. I especially like being able to edit the data.xml file. That helps people like me who do "testing" on parts of the ecu that are undiscovered as of yet.
danl
Postby zlancerman » Sun Sep 10, 2006 3:47 pm
This is perfect timing! I've been waiting for a method to log my AEM UEGO. You mentioned it was untested on this version. Would you like some feedback of how it goes?
zlancerman
Postby AutoXer » Sun Sep 10, 2006 6:52 pm
I seem to be getting data from the LC1, but it looks incorrect. I havn't done any exhaustive testing with it just yet... I had a busy day today. It reads around 19 when my XD16 reads ~14.7. I'll do some more testing tomorrow and report my findings.
I can't see the data stream sub-window any more.
Good things: The gauges rock! The start/stop logging hot keys are handy. The logging color indicator is neat. Not sure what to make of the graphing yet.
...and... No, I haven't gotten "the email" yet, but I do have the software.
AutoXer
Postby turbocharged » Sun Sep 10, 2006 9:14 pm
The LM-1 logging looks good but what happened to the EGT logging?
turbocharged
Postby NoQuarter » Mon Sep 11, 2006 4:24 am
AutoXer wrote:I seem to be getting data from the LC1, but it looks incorrect. I havn't done any exhaustive testing with it just yet... I had a busy day today. It reads around 19 when my XD16 reads ~14.7. I'll do some more testing tomorrow and report my findings.
I have an LC1 and am expecting to get the source code from Evo4Mad. I will also be testing and reviewing the code to assist with getting this part to function if there is indeed a problem.
I have seen the Innovate SDK and I would not expect there to be any problem with the LC-1 if it has been tested with the LM-1.
NoQuarter
Postby andenbre » Mon Sep 11, 2006 7:14 am
I havent had a chance to play with it much yet but so far first impressions are great. the dash and graphing is cool, and the colored back ground while logging is just what the dr ordered
andenbre
