Finished the initial concept of my logger/dash...
Postby Kha0S » Thu Jul 21, 2005 2:13 pm
I've been hacking around with the SSM protocol, and wrote a set of handlers in Processing (which uses a lot of Java, so I spent time looking at ECU for protocol details and JopenECU for Java-specific serial routines).
The advantage of Processing (www.processing.org) is that it supports very rapid development of 2D and 3D graphical primitives. It obviously gives up some efficiency (I'm actually a C/C++ programmer for my day job), but gains a lot for rapid prototypes.
Here's a screenshot of it logging data from my '02 WRX... right now, it only does digital dash and no file logging, and the parameters are hard-coded, but I'm in the process of working on an intuitive GUI to set up the layout and graph types of the dash.
Without further ado, a quick screenshot:
/Andrew
Kha0S
Postby bofh » Thu Jul 21, 2005 4:28 pm
Good start, but what kind of speed will you be able to get?
bofh
Postby Kha0S » Thu Jul 21, 2005 8:09 pm
bofh wrote:Good start, but what kind of speed will you be able to get?
I'm getting data at 9Hz or so (typical for SSM-based loggers), but I've written an interpolation scheme to smooth needle movement substantially that improves the user experience by a lot.
I added some new stuff tonight, including easier variable configuration (still very manual, but it opens things up to a drag/drop system in the near future), colored needles, etc.
After I get all the initial features I want put into the system, I'll release source so people can play around with it.
/Andrew
Kha0S
Postby Kha0S » Fri Jul 22, 2005 5:51 am
I grabbed a video clip of it running this morning... the way I'm capturing video from the application is kind of slow (10fps), so the needle movement isn't nearly as smooth in the video as it is in the actual application... but here it is:
http://www.filefarmer.com/andrewh/ssmlog-video.avi
/Andrew
Kha0S
Postby Kha0S » Fri Jul 22, 2005 9:19 am
... and some more visualization options, and the beginnings of my easy-to-swap variable core underneath...
/Andrew
Kha0S
Postby Student Driver » Fri Jul 22, 2005 10:54 am
Ha! That's very cool. Good job! Hopefully my cable will make it in today or tomorrow, so I can check this out when it's released.
Student Driver
Postby FrSTi » Sat Jul 23, 2005 10:11 am
Looks neat ;)
FrSTi
Postby ahains » Sat Jul 23, 2005 12:15 pm
Cool beans, good stuff :)
-Adrian
ahains
Postby Kha0S » Sat Jul 23, 2005 3:31 pm
A shot with a partial version of the drag-and-drop interface... just need to add gauge create/delete functions and an option to save/load gauge layouts.
/Andrew
Kha0S
Postby west_minist » Mon Jul 25, 2005 6:08 pm
Wonderful!
Keep up the good work KhaOs
Postby calvinc » Mon Jul 25, 2005 9:42 pm
looks very nice. well done.
Postby twg » Mon Aug 22, 2005 8:38 am
Good job!!
I've been thinking of putting a carputer into my car... and running the tactrix cable with some sort of software like this... so a virtual guage pack if you will...
let us know when a user downloadable version is avail...
twg
Postby scooby_x » Sat Sep 03, 2005 9:58 pm
any news on this? i am really interested...save me a couple grand in gauges 8)
scooby_x
Postby tcrown » Wed Sep 07, 2005 6:02 am
I'm anxiously awaiting this as well. If you need any help beta testing and such, I've got my Tari and tactrix cable going. (spent a lot of time testing software and filing bug reports, btw)
Keep up the good work.
tcrown
Postby megafrenzy » Sun Sep 18, 2005 6:19 pm
Wow, nice work, the video is great, awesome response. Is this project still alive??? If not, do you want to make it open source so we can keep it going??
Could it be able to run on a 7" Widescreen LCD (800x600 Stretched) resolution so I can run it in my car computer?
megafrenzy
