Mitsubishi Lancer Evolution 4/5/6/7/8/9 EvoScan Project v0.8
Postby evo400 » Fri Sep 01, 2006 7:52 am
evo400 wrote:
domsub wrote:
evo400 wrote:I has paid for the Evoscan but cant log my ECU. It is EVO IX GSR EDM, EcuFlash OK, but EvoScan ends loging after one value. I am using Czech Windows XP.
Please can you help me?
Change your regionals setting an put '.' as séparator decimal and not comma (,).
This is your problem
:shock: this looks to be realistic, ill try that
Thank you DOMSUB!
It was the decimal separator, liek you said. In Czech language we use "," but english spoken countries use "." After changing this in Control Panels in Windows is everything working now, and also the super speed.
evo400
Postby domsub » Fri Sep 01, 2006 11:31 am
you're welcome ;)
domsub
Postby evo400 » Fri Sep 01, 2006 11:40 am
domsub wrote:you're welcome ;)
I am now rewriting the definition, because i want it in metric (°C) + ill convert the calculations from x=0.123 to x=123/1000 and this will be more compatible :wink:
evo400
Postby laakness » Fri Sep 01, 2006 3:34 pm
Any estimate on the dev time left Evo4Mad? Not a date ;)
laakness
Postby Evo4Mad » Fri Sep 01, 2006 11:21 pm
about 1hr of testing left on wideband, and 30minute left on hotkey support
Postby laakness » Sat Sep 02, 2006 4:52 am
Very cool.
The other reason I've been anxious about this is that I started a Wikipedia page for Evoscan but didn't want to start documenting how to use it until this new version was out, especially with the new features.
laakness
Postby laakness » Sun Sep 03, 2006 11:46 am
One small feature request Evo4Mad....
I was doing some logging today and noticed that with sunlight I can't read the status box to save my life. Could you make like a colored section on the screen or have something big and obnoxious change color so you know when you are logging and when you are not?
laakness
Postby rwunsche » Mon Sep 04, 2006 6:39 am
Is there any chance of getting a release now with the real-time graphing/dashboard functions, instead of waiting for the WB stuff to be completed?
rwunsche
Postby Evo4Mad » Mon Sep 04, 2006 5:06 pm
Ok sounds good I'll do some status indicator when I finish of the start/stop hotkey today, I have now got about 6hrs per day to work on EvoScan now.. I'll finish the LM1 WB support for v0.9, a lot of people are keen on this, myself included :)
I've updated the data.xml file for Evo9's (thanks jcsbanks/s54fan)
3 bar MAP sensor
AFR map lookup value (128=14.7:1)
Vehicle speed
Octane number
Load Calculation (experimental)
laakness wrote:One small feature request Evo4Mad....
Postby laakness » Mon Sep 04, 2006 8:12 pm
Keep up the good work...I think this "no date" thing is working out. There are no expectations that way. It's been another week and I didn't even notice as I wasn't really waiting ;)
laakness
Postby Evo4Mad » Mon Sep 04, 2006 10:19 pm
I have set the start/stop datalogger global windows hotkey to be CTRL- SPACE
I couldn't decide on if the whole form should change color or just the button or the logging status windows.. I have gone with the logging status windows.. and isn't turned on by default, it is under the logging option menu.
Postby laakness » Tue Sep 05, 2006 5:26 am
That sounds great. Some people might not want to turn it on so thumbs up 8)
laakness
Knocksum Alarm?
Postby SilverBack » Tue Sep 05, 2006 9:06 am
I have just been wondering if it is possible to hear an alarm sound from the laptop speakers while under full throttle... if it could be heard, it would be great to be able to set a sound for different knocksum figures as they are received while logging. I could set a nasty noise to warn me if say a 4 or above was received while logging rather than having to wait to view the log after the run.
Just a thought...
SilverBack
Postby rwunsche » Tue Sep 05, 2006 9:34 am
Per EVO4Mad's website, this should be a future feature, I assume included with the graphing/gauge stuff.
Here's the exact quote, "14) Alerting on data value minimum/maximum/rate of change Alerts by Background colour, and/or by custom alarm sound (wav file)."
rwunsche
Postby Evo4Mad » Tue Sep 05, 2006 2:53 pm
This is going to be v1.0 feature, along with totally enhancing the graphing comparision capabilities for multiple log runs.
