evoscan Error: Index was outside the bounds of the array.
Postby coldturbo » Sat Jan 12, 2013 2:12 pm
Tactrix 2.0 cable on 2002 Subaru WRX
Tried Evoscan 2.7, 2.8, 2.9. Keep getting the same error.
Info: OpenPort Firmware v1.12.368
Info: Battery 14.003V
Info: Initialize Vehicle ECU...
Info: Starting Subaru SSMII Init...
Info: Received 0 Data Bytes.
Info: Connection successful..
Info: Datalogger Ended
This error does not happen with my 1.3u cable.
RomRadier/ecuflash works with both cables fine.
Process of elimination has led me to evoscan's tactrix 2.0 driver. I tried the tip listed for 2.7 by renaming the op20pt32.dll to op20pt32.old. If I start evoscan it then reinstalls a new op20pt32.dll. Somethings is not jiving.
Any help would be appreciated.
coldturbo
Users browsing this forum: Google [Bot] and 2 guests
