Can't log '08 LGT-ECUflash defs won't load
Postby blackturboblack » Mon Dec 28, 2009 5:29 am
I just can't get the updated defs to load into ECUflash. I'm using windows 7 and running as administrator. I followed the instructions and deleted the subaru file from the romdata folder and replaced it with the newest one. When I open the new subaru folder, I see my car, but ECUflash isn't displaying the updated models, just the older ones. This is what the log window says:
[07:35:07.961] EcuFlash Version 1.42.2595
[07:35:07.961] OS Version Windows Vista
[07:35:07.961] Qt Version 4.5.0
[07:35:07.976] 56 memory models read.
[07:35:07.976] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[07:35:10.394] 345 ROM metadata models scanned.
[07:35:10.394] checksum module "subarudbw" loaded.
[07:35:10.394] checksum module "mitsucan" loaded.
[07:35:10.394] flashing tool "wrx02" loaded.
[07:35:10.394] flashing tool "wrx04" loaded.
[07:35:10.394] flashing tool "sti04" loaded.
[07:35:10.394] flashing tool "sti05" loaded.
[07:35:10.394] flashing tool "mitsukernel" loaded.
[07:35:10.394] flashing tool "mitsukernelocp" loaded.
[07:35:10.394] flashing tool "mitsubootloader" loaded.
[07:35:10.394] flashing tool "shbootmode" loaded.
[07:35:10.410] flashing tool "shaudmode" loaded.
[07:35:10.410] flashing tool "subarucan" loaded.
[07:35:10.410] flashing tool "mitsucan" loaded.
[07:35:47.086] J2534 API Version: 04.04
[07:35:47.086] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[07:35:47.086] Device Firmware Version: 1.10.2658
[07:35:49.270] interface close
Wha tis going on here?
blackturboblack
Re: Can't log '08 LGT-ECUflash defs won't load
Postby rollertoaster » Tue Apr 27, 2010 5:55 pm
I'm having a similar problem I think
ecu flash works fine, I can retrieve my rom and save it. I can open it in RR editor and I'm able to see that my standard def file and my 2010wrx file are being recognized. When I switch to Logger I can only select either the standard def file or my 2010wrx def file (which is not working). Also it will not connect to the interface using logger, but works fine with ecu flash
These are the Defs I'm using
http://www.romraider.com/forum/topic5676.html
the logger worked yesterday, I can't seem to grasp why today is different.
On an aside note, after retrieving my image and trying to connect with logger, sometimes the car will not start. I'm not even attempting a test write, Luckily after a minute or two it will then start. Any ideas why this is happening?
edit: I managed to catch the error that is displayed
Error: org.xml.sax.SAXParseExeption: the processing instruction target matching "[xX][mM][lL]" is not allowed
my 2010.hex
my 2010 usdm wrx
(1 MiB) Downloaded 1111 times
rollertoaster
