can't log my 07 wrx help
Postby kjc227 » Wed Nov 11, 2009 4:44 am
has anyone had a problem logging with 2.0 cable using romraider cause can't seem to log my 07 wrx can any one help?? it says unable to send ecu init or check cable is connected or ecu id unknown can't get pass that can any one help???
kjc227
Re: can't log my 07 wrx help
Postby pavlik1 » Tue Nov 24, 2009 3:26 am
YES I have the same problem, but unfortunately have no solution
I hope the designer of OP2.0 can give some support
pavlik1
Postby mohammadov » Mon Nov 30, 2009 1:17 am
Check Com port firstly.
right click on My Computer-->Properties-->Device Manager-->Ports(COM & LPT) u can see clearly what port is the OP2..then go to RomRaider Logger, and choose the com port from the list.
u should also run it as administrator if u are using vista.
and u must dedicate the logger definitions from romraider website.
mohammadov
Postby pavlik1 » Tue Dec 01, 2009 2:16 am
all done,
I try it one more time and post the result
pavlik1
