Mut-Monitor V1.7 (Working with OP2.0)
Postby CLaNZeR » Sat Jan 24, 2009 11:22 am
Just realised I had not posted updates in here since Version 1.3 of Mut-Monitor.
******Now you can Log using MUT Protocol EVO 4-9 with your OpenPort 2.0 Cable *******
New FREEWARE Test Version 1.7 of Mut Monitor.
Can be downloaded at http://www.myrollingroad.com/showthread.php?t=97
(Sorry you must be register to download)
This application uses the Mitsubishi MUT Protocol for monitoring data from the Vehicles ECU.
It can be used with OBD-II serial cables as well as FTDI based cables via Direct calls or Virtual Com Ports. At this time it seems to be the only application that will Log with the Tactrix OpenPort V2.0 Cable on Mitsubishi Vehicles.
Now works with CLaNZeR's USB-PIC-OBD Cable at high logging speeds.
Check the cable out here:
http://www.myrollingroad.com/showthread.php?t=80
Main Changes for Version 1.7 are:
Added support for CLaNZeR'S USB-PIC-OBD cable.
Cleaned up alot of the code for the Timeouts.
Cheers
Sean.
CLaNZeR
