problem logging with openport 2.0
Postby rasheedn » Fri Jan 09, 2009 7:36 am
hi there,
i just bought the new cable to use with my 09 sti
tired to download my map and worked fine with ecuflash.
then tried to do some logging and it wont work. i tried with romraider and ecuexplorer and nothing even ecu-edit wont work
i tried to turn car on/off lock unlock... nothing it just wont connect
so i got my old 1.5 cable and it works fine!! i can log and view the car.
anyone got any ideas??
btw: ecuflash 1.40.2178.
thanks for looking
rasheedn
Re: problem logging with openport 2.0
Postby merchgod » Fri Jan 09, 2009 1:53 pm
You need to use RomRaider 0.5.1b - it is the only version of RomRaider that will log with the OP 2.0. Any other logging programs that worked with the old cable will not be compatible with 2.0 unless the developer(s) specifically add support for it.
merchgod
Users browsing this forum: No registered users and 4 guests
