Mitsulogger and Evoscan won't work
Postby Zamot » Wed Apr 25, 2007 8:30 am
Both programs are up and running, but when I start logging, the programs crash.
(By the way, I have managed to use ECUflash to download the ROM.)
Not shure, but I suspect some trouble with .Net or something. I have tried to install .NET 3, and later 2. Also Java. I'm not shure how to check this though, any tips?
Also, are there any step-by-step guides in how to uninstall and then install everyting needed(.NET, Java, and the programs)?
The Evoscan says something about an .xml file.
Mitsulogger fault:
************** Exception Text **************
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at MitsuLogger.x751922eb1bfae5fb.x9019a79b966d57d0(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Zamot
