Trouble with EvoScan gauge widgets
Postby TouringBubble » Fri Mar 30, 2007 4:26 am
I started working on a nice gauge set for EvoScan before I even got my Tactrix cable. It looks sweet, but I can't get it to work. I actually can't get ANY gauges to work. I can set the pointers to "interactive" and they work just fine, but I get nothing while logging or during playback.
These are my assumptions:
1) Pointer Input is remapped when you select an input source from the EvoScan setup window. I have tried mapping the input to "none" and "default" in the wizard, but those are my only choices.
2) Setting input values to "default" will make the gauge inherit it's parent's input source and scale.
Those should be the only things that would affect the function, correct? I mean, if I have those settings correct something should happen ... even if it is not exactly what I want ... right?
Any help would be appreciated. Thanks.
TouringBubble
Postby TouringBubble » Fri Mar 30, 2007 3:46 pm
Nevermind, got it fixed. They started working after installing .99. Look for my OEM Evo gauge template soon ...
TouringBubble
