Context:
Installed a Zeitronix ZT-2 WBo2 this week. EvoScan can log it beautifully, even if I intermittently get a BSOD when stopping the logging process. However, if I quit out of EvoScan, it loses my selected WBo2 and COM port settings; I have to remember to set them correctly else I get garbage data in the WB column.
The BSOD causes me to reboot and restart EvoScan, which then defaults to the Innovate LC-1 (the first item in the list). I've sorted out the COM port by hackish methods - setting the USB-serial adapter to use COM1 (again, the first item in the list).
Has anyone sussed out a method to default a wideband sensor type in EvoScan?
