wetwilly wrote:The dashboard display wasn't so great. It looks nice but the needles didn't move smoothly and the displayed values for boost lagged by several seconds. It was hard to tell if the displayed values for boost were accurate, but the IAT looked OK since it didn't vary much and seemed to be correct. I didn't know what TPS was (throttle position sensor??), so couldn't tell if that was accurate.
I also got several error messages while running, which would then dump the program. One appeared as soon as I went WOT to see if I could get the boost needle to move. Maybe due to increased updates overwhelming the comm port? Then after running for several minutes OK, while displaying the graphs, the program froze up which also froze my PC and had to reboot.
I'm running on an EPIA M9000, 512M ram, with a 7 inch LCD indash. The display definitely needs to be skinnable to be easily visible on a display that size. I was running one other program at the time, playing MP3s. I probably should have turned it off while testing, but this is how I would use the program.
wetwilly wrote:OK didn't know about disabling graphing. That sped up the dashboard dials a lot, but they are still jerky. Maybe you could add some smoothing routine.
I run 800x600 on my 7 in lcd.
I wasn't starting or stopping logs when the errors occurred.
Can the dashboard dials be changed to display different parameters?
