Timing with 94+ octane
Postby m3n0ch3 » Mon Nov 06, 2006 1:23 pm
Hi guys,
I'm finishing tuning my car with 94 octane and I'm seeing results that are a bit amazing not to say weird..
Is it normal that with 94, under big load that I can still get timing values of 29-32 degrees before it pings?
when I say high load I'm talking 4.75+
the initial maps for a wrx will not allow more than 15 for the same cells?
I always though with 94 i could get 3-5 degrees plus but 15 sounds a lot isn't it?
Phil
m3n0ch3
Postby m3n0ch3 » Tue Nov 07, 2006 8:07 pm
Am I the only one on this board having access to 94 octane???
I'm a bit shocked....
m3n0ch3
Postby MRF582 » Wed Nov 08, 2006 9:54 am
I've got access to 94 but only running 93 since it is more widely available. With 93 I'm slowly working my way up and am at a knock free 23* around 4.75 engine load in the high rpms. But I think I should be able to get 25 degrees out of it with relative ease.
So your 29-30 degrees is still impressive but not too far off.
MRF582
Postby m3n0ch3 » Wed Nov 08, 2006 10:18 am
what kind of temperature are you having in your area?.
in here it's between 0 and 10 C
m3n0ch3
Users browsing this forum: Bing [Bot] and 23 guests
