- Code: Select all
[00:43:18.396] reading ecu programming voltage
[00:43:18.446] programming voltage is 4.24 volts
[00:43:18.446] programming voltage is out of range!
[00:43:18.446] kernel flash disable
Reading and comparing ROM images seems to work just fine. The only other error I see is "error loading FTD2XX.DLL" when I start up EcuFlash.
