JRSCCivic98 wrote:I'm talking about taking the current EDM flashes and putting them on a matching year ECU, as in 04 to 04 and 05 to 05. Seems though that the older 02-03 USDM ECUs might not have any issues running the new 04+ EDM ROMS. Something tells me that the EDM ECUs probably didn't change since 02.
JRSCCivic98 wrote:Maybe we need to find out from Colby what the major differences are between the 02-03 flash methods and the 04+ ones. Does the flash method need to correspond somehow with the data or is that strickly something just used for interfacing and uploading the kernel? If they don't have to coinside and we're going to start flashing different ROMs on different ECUs to get what we want then it's going to be imperative that he change the way the flash methods are currently being implemented (take them back out of the xml and put them back as a menu choice).
mattims wrote:it certainly does make boost tuning really easy. I tuned the boost from 0.7 bar to 1.1 bar on my car in about 2 flashes (and this was the first tuning i had ever done) simply by raising the wastegate duties nearly to max so it would hit it in 2 second gear and the take about 10% of in 3rd about 15% in fourth and 20% in 5th. Its a very useful table. It also comes with a boost target compensation table (which from factory reduces boost in 1st,2nd and 5th) i removed it from 1st and 2nd and left the reduction on 5th. Car pulls away much better now and i have no spiking issues in 5th (i actually hit my highest boost peak in 3rd)
