SilverBack wrote:Thanks.
Are the keys coded to the ECU or the ECU coded to the keys?
I mean, if I get another ECU and get the imobiliser sorted on the second ECU, can I then just swap between the two or will the 're-code' need to be done each time the ECU is swapped?
The keys are coded to the immobilizer. The ECU is also coded to the immobilizer. However, the two codes are independent of each other. You need to have the immobilizer code for the ECU.
I believe I'm in the same boat as you. I have a second ECU, but I can't get the immobilizer code off of my existing ECU. It's driving me nuts!
Al(Dynoflash), said that he can get the code off my working ECU, but he'd charge me for it. I'm waiting to see if a free fix emerges. I can't believe you and I are the only ones in this situation.
