When I open it in Enginuity as a 160K ROM, there are errors saying that some parameters are out of bounds.
So, I convert the image to 192K and run it again, there are fields that apparently enable disabling sensors.
Only problem is that it's obvious the code is lost because the values are wacky.
Wondering if there's a way to pull the entire 192K region?
-Jason
