2006 ADM Liberty (legacy) 3.0R Spec.B MT - cant read
Postby antus » Fri Jul 05, 2013 11:34 pm
Hi Guys,
Standard disclaimer, Im not experienced with subaru tuning and may be missing something obvious. Ive read the forums here and at romraider, and am not sure if my issue is user error or because my car is not supported.
I have the latest version of ecuflash installed, it updated my openport 2.0 firmware, but attempts to read the car only net this:
[21:31:05.014] Device Firmware Version: 1.12.3688
[21:31:05.014] Device Serial Number: TAI$ij9f
[21:31:05.216] SSM2 init
[21:31:05.357] SSM2 ECU ID is 455A384006
[21:31:05.435] Requesting Seed...
[21:31:05.482] Sending Key...
[21:31:06.106] interface close
[21:31:06.137] interface close
I have seen some models require jumping of a green wire, but I dont think this vehicle is one of them. Attempting to use can read options result in nothing, not even an ecu ID. Searching on the above ecu id, i only get one hit.. this thread here which claims they got the same output on a subaru BRZ !?!? http://www.romraider.com/forum/viewtopi ... 5&start=75
Is this ecu expected to work, and if so any ideas what to check?
antus
Re: 2006 ADM Liberty (legacy) 3.0R Spec.B MT - cant read
Postby KanScooby » Sat Jul 06, 2013 12:12 am
I think you might need to connect the green test mode connectors for a read. There might be located near the ecu on the front passenger foot rest.
KanScooby
Postby antus » Sun Jul 07, 2013 4:32 am
ok thanks, i'll see what i can find.
antus
Postby antus » Sun Jul 07, 2013 7:04 pm
I had a fish around the kick panels and fuse box, but nothing jumped out at me. Can you see anything here that looks like it might need connecting to read? Theres a couple of green connectors behind the driver kick panel, but they were already connected.
antus
Postby volik8 » Sat Nov 23, 2013 5:58 am
Connect the green connector from the passengers in the legs under the mat
turn away mat and you see it
After connecting, when the ignition must be switched radiator fan with a periodicity
Ask any questions on http://WWW.Subaru-dtc.com
volik8
Users browsing this forum: Bing [Bot] and 22 guests
