Problems reading from ECU
Postby subarusmasher » Mon May 15, 2006 8:49 am
I've been trying to read from the ECU of a 2001 UK WRX (with PPP) without success.
I've jumpered the 2 spades in the white connector, connected the green test connectors and turned on the ign. before reading.
I get a "Kernel get version" message in the debug window, which then throws an error window suggesting that i check the log for details? - The process then aborts? :cry:
Does anyone know what the problem is and how i can resolve it? - I'm using the latest version of ECU Flash.
subarusmasher
Postby cboles » Mon May 15, 2006 9:26 am
what cable are you using?
Postby subarusmasher » Tue May 16, 2006 12:30 am
I'm using the later 1.2 cable.
subarusmasher
Postby swifty » Tue May 16, 2006 1:03 am
It's probably just a timing issue.
Don't turn on the ignition until you press the OK button in ECUflash then turn it on as quickly as you can after pressing ok.
Are you in the UK ? If so I'm happy to help you out depending on where you are.
swifty
Postby johnwrx » Tue May 16, 2006 1:47 am
Hello, :)
I've got the same problem and now works :)
This is what i do:
Turn off ingnition
---Open Ecuflash
---Click the button with ecuread
---it will come a little window that say's to turn on the ignition
---put the mouse over the ok on the window
---turn on the ignition
---and sooo quick click the ok button on the window
---and start to read
I've an WRX EU 2001 with A4SE700D think the same like You.
johnwrx
Postby subarusmasher » Thu May 18, 2006 9:13 am
Doesn't seem to make any difference what order i do thing in, i still get the same message - "Kernel" get version"
Anybody got any other ideas as to what could be wrong, or what i'm missing? :?
subarusmasher
Postby Synx » Thu May 18, 2006 6:16 pm
Same issue here, although im using a COBB AP cable, i swear i read that it was working now with the AP cables. I'm getting the get kernel error, and ive also got a "error loading FTD2XX.DLL" as well when EcuFlash loads. Any ideas?
Synx
Postby JRSCCivic98 » Fri May 19, 2006 5:42 am
Can't do it with the Cobb cable. It's for isht.
Postby Synx » Fri May 19, 2006 9:16 am
Actually got it working, needed to jump the flash write plug even for the read. Finally i can get in here and play around.
Synx
Postby scotty » Sat May 20, 2006 11:20 pm
i have exactly the same problem on my 02 EU STI and i so would like to know what jumpers i have to add to have it working, i have ordered the both with my 1.2 openport, is there any risk if i plug them at the same time
in the beggining of ecuflash, i can't find my car too, is it a problem or not?
scotty
Postby turbocharged » Mon May 22, 2006 4:59 pm
I have the same prob connecting to the ECU of a MY04 EU WRX. Is it really a timing issue cause I tried everything listed here and it still can't read.
turbocharged
