cannot download the stock rom
Postby kernkern » Thu Apr 12, 2012 9:18 pm
My car 09 EDM legacy 2.0NA 4AT and without ecutek
first time use the openport 2.0
this is my log, I cannot save my stock rom
[11:53:10.192] EcuFlash Version 1.43.3150
[11:53:10.192] OS Version Windows 7
[11:53:10.192] Qt Version 4.6.2
[11:53:10.209] 62 memory models read.
[11:53:10.210] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[11:53:10.622] 354 ROM metadata models scanned.
[11:53:10.622] checksum module "subarudbw" loaded.
[11:53:10.622] checksum module "mitsucan" loaded.
[11:53:10.622] checksum module "mitsuh8" loaded.
[11:53:10.623] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[11:53:10.623] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[11:53:10.623] flashing tool "wrx02" loaded.
[11:53:10.623] flashing tool "wrx04" loaded.
[11:53:10.624] flashing tool "sti04" loaded.
[11:53:10.624] flashing tool "sti05" loaded.
[11:53:10.624] flashing tool "mitsukernel" loaded.
[11:53:10.624] flashing tool "mitsukernelocp" loaded.
[11:53:10.624] flashing tool "mitsubootloader" loaded.
[11:53:10.624] flashing tool "shbootmode" loaded.
[11:53:10.626] flashing tool "shaudmode" loaded.
[11:53:10.626] flashing tool "subarucan" loaded.
[11:53:10.627] flashing tool "mitsucan" loaded.
[11:53:27.106] J2534 error [device not responding].
[11:53:27.106] unable to connect to vehicle interface.
[11:53:27.106] interface close
[11:53:36.691] reading firmware
[11:53:36.730] flash file version is 1.11.3137
[11:53:36.944] main code version : 1.10.3020
[11:53:36.947] waiting for bootloader (may be installing drivers)... press any key to abort
[11:53:46.014] connecting to bootloader on \
[11:53:46.036] tri bootloader version : 1.00.1923
build date : Jul 31 2008
build time : 18:07:47
IAP boot code version : 03.04
part ID : 1600F902
code protection : 87654321
serial number : TAn*jRMT
[11:53:47.073] ---erasing---
[11:53:47.185] erasing 1
[11:53:47.196] ---writing---
[11:53:47.220] writing 1k
[11:53:47.246] writing 2k
[11:53:47.271] writing 3k
[11:53:47.297] writing 4k
[11:53:47.380] writing 5k
[11:53:47.413] writing 6k
[11:53:47.446] writing 7k
[11:53:47.478] writing 8k
[11:53:47.509] writing 9k
[11:53:47.542] writing 10k
[11:53:47.576] writing 11k
[11:53:47.609] writing 12k
[11:53:47.642] writing 13k
[11:53:47.675] writing 14k
[11:53:47.709] writing 15k
[11:53:47.742] writing 16k
[11:53:47.775] writing 17k
[11:53:47.808] writing 18k
[11:53:47.841] writing 19k
[11:53:47.873] writing 20k
[11:53:47.905] writing 21k
[11:53:47.938] writing 22k
[11:53:47.972] writing 23k
[11:53:48.005] writing 24k
[11:53:48.037] writing 25k
[11:53:48.070] writing 26k
[11:53:48.103] writing 27k
[11:53:48.135] writing 28k
[11:53:48.167] writing 29k
[11:53:48.202] writing 30k
[11:53:48.234] writing 31k
[11:53:48.266] writing 32k
[11:53:48.297] writing 33k
[11:53:48.330] writing 34k
[11:53:48.363] writing 35k
[11:53:48.396] writing 36k
[11:53:48.429] writing 37k
[11:53:48.462] writing 38k
[11:53:48.494] writing 39k
[11:53:48.527] writing 40k
[11:53:48.558] writing 41k
[11:53:48.592] writing 42k
[11:53:48.625] writing 43k
[11:53:48.658] writing 44k
[11:53:48.691] writing 45k
[11:53:48.725] writing 46k
[11:53:48.758] writing 47k
[11:53:48.791] writing 48k
[11:53:48.824] writing 49k
[11:53:48.856] writing 50k
[11:53:48.889] writing 51k
[11:53:48.922] writing 52k
[11:53:48.954] writing 53k
[11:53:48.986] writing 54k
[11:53:49.019] writing 55k
[11:53:49.052] writing 56k
[11:53:49.086] writing 57k
[11:53:49.120] writing 58k
[11:53:49.155] writing 59k
[11:53:49.192] writing 60k
[11:53:49.223] writing 61k
[11:53:49.257] writing 62k
[11:53:49.291] writing 63k
[11:53:49.325] writing 64k
[11:53:49.358] writing 65k
[11:53:49.394] writing 66k
[11:53:49.427] writing 67k
[11:53:49.462] writing 68k
[11:53:49.475] flash complete!!!
[11:53:56.045] J2534 error [ERR_TIMEOUT].
[11:53:56.045] unable to connect to vehicle interface.
[11:53:56.045] interface close
any suggestion
thanks!
Ben
kernkern
Re: cannot download the stock rom
Postby Wiretap » Thu Apr 12, 2012 9:58 pm
Are you trying to READ or WRITE? It looks to me like it's trying to write?
Wiretap
Postby kernkern » Thu Apr 12, 2012 10:23 pm
thanks your reply!!
I try to download the stock rom
use the "Read from ECU"
I think it is READ
kernkern
Postby kernkern » Sat Apr 14, 2012 2:50 pm
I try it many times
get the log repeat....
[06:47:11.312] J2534 API Version: 04.04
[06:47:11.312] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[06:47:11.312] Device Firmware Version: 1.11.3209
[06:47:11.312] Device Serial Number: TAn*jRMT
[06:47:12.515] kernel get version
[06:47:12.765] VIN : JF1BP5LS59G123265
[06:47:12.781] CVN : C798313E
[06:47:12.781] SSM2 init
[06:47:12.953] SSM2 ECU ID is 5244304007
[06:47:12.984] Requesting Seed...
[06:47:13.000] Sending Key...
[06:47:13.015] interface close
[06:47:13.031] interface close
I download the
ECU FLASH v1.42.3252 here http://www.evoscan.com/free-ecu-rom-downloads and setup
but it can not download too......
and I have try win7 and XP laptop ............ result same....
kernkern
Postby Sasha_A80 » Sat Apr 14, 2012 9:31 pm
Look at the case of your ecu.
This may be Hitachi not supported by ecuFlash.
Sasha_A80
Postby bmcrally » Tue Apr 17, 2012 12:49 am
I have the same problem.
Definately a supported ECU, in my ADM Subaru MY06 WRX.
I installed the latest Beta of Ecu Flash 1.43.3150 and when I connected to the ECU and attempted to read, it updated the Bootloader in the Openport 2.0
(you can see this behaviour in the original post, at timestamp [11:53:36.947] to [11:53:49.475]
All subsequent attempts to read from the ECU return multiple "SSM2 init" messages and a timeout.
I suspect the new firmware updated in the Openport 2.0 isn't quite right yet, at least on my Subaru.
So is there a way I can reload older firmware into the Tactrix Openport 2.0 ?
Thanks in advance
Brett
bmcrally
Postby bmcrally » Thu Apr 19, 2012 5:37 pm
Kernkern,
I emailed Tactrix support directly and I think they have nailed the problem, although I haven't been able to test yet.
I had thought that all DBW Subarus didn't require the green test connectors under the dash to be joined, but it is only the extra jumper that isn't required.
Try following, my car reacted as stated and I expect that is the cause of not reading. As your car is an 09 it may be CAN bus and not require the test mode jumper connected, but it's worth a try.
Q: I am having problems reading or flashing with EcuFlash. What should I do?
- Reading and flashing require you to enter ‘test mode’ by connecting the green diagnostic connectors located above the driver’s side foot well (non-CAN models only). Make sure your car is actually entering test mode. With the green diagnostics connectors connected and the OpenPort cable disconnected, you should get a flashing CEL and the radiator fans should cycle on and off (after a period of time) when the ignition is turned on. If not, your car may have an additional connection near the passenger’s side foot well that is disconnected. When reading and flashing begins, the radiator fans will remain off.
- Do not turn on your ignition until prompted by EcuFlash to do so and when you do, immediately hit ‘OK’, otherwise reading/flashing may fail (any moderate delay on your part can result in a failure). If you wait until the radiator fans begin to cycle, then you have waited too long. Note: The engine should NEVER be running when reading or flashing.
I would appreciate it if you can update this post when you get a result one way or the other as I won't be able to try this until next week.
Brett
bmcrally
Postby kernkern » Fri Apr 20, 2012 2:41 am
Brett,
Thanks your info, I will try it this weekend.
If this method work for your car, share it to me please.
Thanks!!
Ben
kernkern
Postby kernkern » Fri Apr 20, 2012 3:05 pm
Today I try to pull the stock rom again
I can hear radiator fans cycle on and off but no CEL flash
and try to download by ecuflash , fail....
the log .....
[06:52:24.848] J2534 API Version: 04.04
[06:52:24.848] J2534 DLL Version: 1.00.3210 Nov 22 2010 23:18:50
[06:52:24.848] Device Firmware Version: 1.11.3209
[06:52:24.848] Device Serial Number: TAn*jRMT
[06:52:25.028] kernel get version
[06:52:25.298] VIN : JF1BP5LS59G123265
[06:52:25.318] CVN : C798313E
[06:52:25.318] SSM2 init
[06:52:25.498] SSM2 ECU ID is 5244304007
[06:52:25.518] Requesting Seed...
[06:52:25.540] Sending Key...
[06:52:25.559] interface close
[06:52:25.577] interface close
kernkern
Postby bmcrally » Tue Apr 24, 2012 12:56 am
Ben,
I followed the instructions from Tactrix on my ADM MY06 WRX today and it worked flawlessly.
I suggest you do this:
ignition off
connect green dignostic plugs under dash (fans should cycle and check engine light should come on)
connect Tactrix, connect USB to PC
open ecuflash
click on read ecu
when asked if the ignition is already on, say yes (even though it isn't)
ECUFlash will start trying to communicate with the ecu, but get no response as the ignition is off
turn ignition on and ECUFlash should start reading as soon as it initialises
I can also confirm that ROMRaider and Ecuedit both communicate correctly using the new Tactrix driver.
Now I can get on with swapping turbos and then start retuning.
cheers
Brett
bmcrally
Postby kernkern » Tue Apr 24, 2012 4:41 pm
Brett,
It's good.
" ECUFlash will start trying to communicate with the ecu, but get no response as the ignition is off "
get no response the as the ignition is off --> ECUFlash reply ""interface close"" ?? or ECUFlash waiting to connect , It show any info ??
I will try your suggestion.
Thanks!!
kernkern
