08 USDM STI cant read ecu
Postby qban-rex » Fri Mar 16, 2012 9:19 am
Hello all,
I recently purchased my08 STI and i am trying to at least read the ecu from it. i plan on doing some light bolt-ons so i need the access.. I used to have a my02 bug which i waqs able to read and write to ecu with my old 1.3 cable.. now i have purchased the OP 2.0 from tac trix and i am having a hell of a time trying to connect. always get the same error.
[13:10:46.296] EcuFlash Version 1.43.3150
[13:10:46.296] OS Version Windows XP
[13:10:46.296] Qt Version 4.6.2
[13:10:46.312] 62 memory models read.
[13:10:46.312] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[13:10:46.656] 354 ROM metadata models scanned.
[13:10:46.656] checksum module "subarudbw" loaded.
[13:10:46.656] checksum module "mitsucan" loaded.
[13:10:46.656] checksum module "mitsuh8" loaded.
[13:10:46.656] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[13:10:46.656] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[13:10:46.656] flashing tool "wrx02" loaded.
[13:10:46.656] flashing tool "wrx04" loaded.
[13:10:46.656] flashing tool "sti04" loaded.
[13:10:46.656] flashing tool "sti05" loaded.
[13:10:46.656] flashing tool "mitsukernel" loaded.
[13:10:46.656] flashing tool "mitsukernelocp" loaded.
[13:10:46.671] flashing tool "mitsubootloader" loaded.
[13:10:46.671] flashing tool "shbootmode" loaded.
[13:10:46.671] flashing tool "shaudmode" loaded.
[13:10:46.671] flashing tool "subarucan" loaded.
[13:10:46.671] flashing tool "mitsucan" loaded.
[13:10:53.500] J2534 API Version: 04.04
[13:10:53.500] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[13:10:53.500] Device Firmware Version: 1.11.3209
[13:10:53.500] Device Serial Number: TAzk6LOh
[13:11:02.000] kernel get version
[13:11:02.218] VIN : JF1GR89638L825492
[13:11:02.218] CVN : 369893B7
[13:11:02.218] SSM2 init
[13:11:02.265] SSM2 ECU ID is 5A12784107
[13:11:02.265] Requesting Seed...
[13:11:02.265] Sending Key...
[13:11:02.265] interface close
[13:11:02.281] interface close
I have updated the drivers to the Tactrix open port.. i have uninstalled and reinstalled both ecuflash and the drivers to the tactrix 2.0 dongle.. with the older drivers i can reset the ecu with romraider but still cannot read ecu.. I have tried searching thru all the forums but to no avail was not able to help.. I hope someone can assist me ..
thank you in advance and for your time
Rolando
qban-rex
Re: 08 USDM STI cant read ecu
Postby radsdau » Sun Mar 18, 2012 3:25 pm
When it fails at that point it usually means the ECU is locked / third party tuned, e.g., EcuTek or Cobb. Find its history and see if you can get it unlocked. Otherwise send it to someone who can revert it to standard using ECU recovery methods. This forum has a number of posts about that and links to people who can help.
I suppose it's worth double checking the green test mode connectors are joined first before you go to the trouble above.
Postby Chris250 » Wed Mar 28, 2012 11:26 am
I'm having the same issues on a UKDM WRX-S 2008, all i get every time i try to read it is
20:22:41.774] J2534 API Version: 04.04
[20:22:41.774] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[20:22:41.774] Device Firmware Version: 1.11.3137
[20:22:41.774] Device Serial Number: TAyuJy5H
[20:22:45.074] kernel get version
[20:22:45.293] VIN : JF1GHEKD38G007006
[20:22:45.308] CVN : EDA88BA6
[20:22:45.308] SSM2 init
[20:22:45.340] SSM2 ECU ID is 5142584007
[20:22:45.340] Requesting Seed...
[20:22:45.340] Sending Key...
[20:22:45.355] interface close
[20:22:45.371] interface close
Anyone any ideas?
Chris250
