can reflash my wrx 05
Postby srpshop » Tue Oct 18, 2011 8:26 am
i try to reflash my car like 10000 times and got nothign try everything and nothing i get this at the log
[11:54:48.219] EcuFlash Version 1.41.2483
[11:54:48.219] OS Version Windows Vista
[11:54:48.219] Qt Version 4.4.0
[11:54:48.226] 26 memory models read.
[11:54:48.226] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash1.41/rommetadata
[11:54:52.582] 342 ROM metadata models scanned.
[11:54:52.582] checksum module "subarudbw" loaded.
[11:54:52.582] checksum module "mitsucan" loaded.
[11:54:52.583] flashing tool "wrx02" loaded.
[11:54:52.583] flashing tool "wrx04" loaded.
[11:54:52.583] flashing tool "sti04" loaded.
[11:54:52.583] flashing tool "sti05" loaded.
[11:54:52.583] flashing tool "mitsukernel" loaded.
[11:54:52.583] flashing tool "mitsukernelocp" loaded.
[11:54:52.583] flashing tool "mitsubootloader" loaded.
[11:54:52.583] flashing tool "shbootmode" loaded.
[11:54:52.646] flashing tool "shaudmode" loaded.
[11:54:52.646] flashing tool "subarucan" loaded.
[11:54:52.646] flashing tool "mitsucan" loaded.
[11:54:56.809] A4RM200K (333 tables) inheriting 16BITBASE (495 tables)
[11:54:56.833] 163840 byte image read.
[11:54:59.593] J2534 API Version: 04.04
[11:54:59.593] J2534 DLL Version: 0.50.2464 Jan 29 2009 10:58:58
[11:54:59.593] Device Firmware Version: 1.11.3157
[11:55:01.258] denso02_bootloader_cmd_start
[11:55:02.470] denso02_bootloader_cmd_start
[11:55:03.680] denso02_bootloader_cmd_start
[11:55:04.890] denso02_bootloader_cmd_start
[11:55:06.101] denso02_bootloader_cmd_start
[11:55:06.510] kernel get version
[11:55:06.819] interface close
[11:55:06.834] interface close
please help
srpshop
Re: can reflash my wrx 05
Postby radsdau » Tue Oct 18, 2011 4:14 pm
Can you please rephrase the statement at the top? I'm having trouble working out what you mean.
Hint: try adding some punctuation. :)
Postby srpshop » Wed Oct 19, 2011 4:20 am
ok i can reflash the car try disconect the battery check the green connectors plug the clamp also battery charger wile i reflash and nothing i get the same error always
srpshop
Postby radsdau » Wed Oct 19, 2011 5:22 pm
I think I'm starting to understand. The punctuation hasn't really improved though has it. :)
So when you say "i can reflash the car" do you actually mean you can't reflash the car?
The symptom you are seeing looks like either one of these:
*the flash jumper block is not connected (probably the 4-terminal version for that model, but I can't be certain), or
*the ECU is locked, e.g., EcuTek.
I'd be checking the first item before assuming it's locked.
Good luck.
Users browsing this forum: No registered users and 45 guests
