help unable to read 05 sti
Postby billion01 » Tue Jun 21, 2011 10:26 pm
Hi guys,
I have a customer who had a cobb accessport installed on his car but then the cobb broke. He installed more parts since then and hit me up to do the retune on the vehicle. I am in test mode and trying to connect but i keep getting these error messages.
[20:11:29.934] flashing tool "shaudmode" loaded.
[20:11:29.934] flashing tool "subarucan" loaded.
[20:11:29.934] flashing tool "mitsucan" loaded.
[20:17:25.580] J2534 API Version: 04.04
[20:17:25.580] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[20:17:25.580] Device Firmware Version: 1.10.2658
[20:17:35.228] kernel get version
[20:17:35.583] SSM2 init
[20:17:35.731] SSM2 ECU ID is 2E 12 49 51 06
[20:17:35.812] Requesting Seed...
[20:17:35.857] Sending Key...
[20:17:35.902] interface close
[20:17:35.913] interface close
[20:17:47.593] J2534 API Version: 04.04
[20:17:47.593] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[20:17:47.593] Device Firmware Version: 1.10.2658
[20:18:02.058] kernel get version
[20:18:02.413] SSM2 init
[20:18:02.560] SSM2 ECU ID is 2E 12 49 51 06
[20:18:02.642] Requesting Seed...
[20:18:02.686] Sending Key...
[20:18:02.732] interface close
[20:18:02.743] interface close
[20:18:51.726] J2534 API Version: 04.04
[20:18:51.727] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[20:18:51.727] Device Firmware Version: 1.10.2658
[20:18:59.885] kernel get version
[20:19:00.240] SSM2 init
[20:19:00.388] SSM2 ECU ID is 2E 12 49 51 06
[20:19:00.470] Requesting Seed...
[20:19:00.515] Sending Key...
[20:19:00.561] interface close
[20:19:00.572] interface close
If the car currently has Cobb loaded am I unable to flash this ecu? I am going to do a search after this so please dont flame me. I am working on a tight deadline so i figured throw it out there while i search.
The fans are cycling and lights are blinking so i figure i am in test mode and i hit the enter key right after turning the key to ign on.
please help and thanks in advance,
billion01
Re: help unable to read 05 sti
Postby radsdau » Wed Jun 22, 2011 4:59 pm
That symptom is indicative of a locked ECU, which is likely if there is Cobb tune in it.
Either get the tuner to unlock it and put the factory tune back in, or if that's not an option, send it to someone to unlock it for you.
