Problem with EcuFlash
Postby tanxunhong » Sun Jun 19, 2011 7:04 am
I just started playing with this stuff n met with some problem.
do need some help from you guys.
I am driving an 07 euro STI DBW.
Using Asus Win 7 laptop with OP 2.0
No problem using Romraider to do logging.
but when i try using ecuflash i met with some problem.
This is what i do,
1. Plug OBD cable n connect to USB port.
2. On ignition switch n click EcuFlash.
3. click Read From Ecu. & problem came.
This is what it shows,
[20:52:16.714] EcuFlash Version 1.43.3150
[20:52:16.714] OS Version Windows 7
[20:52:16.714] Qt Version 4.6.2
[20:52:16.714] 62 memory models read.
[20:52:16.730] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[20:52:16.855] 354 ROM metadata models scanned.
[20:52:16.855] checksum module "subarudbw" loaded.
[20:52:16.855] checksum module "mitsucan" loaded.
[20:52:16.855] checksum module "mitsuh8" loaded.
[20:52:16.855] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[20:52:16.855] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[20:52:16.855] flashing tool "wrx02" loaded.
[20:52:16.855] flashing tool "wrx04" loaded.
[20:52:16.855] flashing tool "sti04" loaded.
[20:52:16.855] flashing tool "sti05" loaded.
[20:52:16.855] flashing tool "mitsukernel" loaded.
[20:52:16.855] flashing tool "mitsukernelocp" loaded.
[20:52:16.855] flashing tool "mitsubootloader" loaded.
[20:52:16.855] flashing tool "shbootmode" loaded.
[20:52:16.855] flashing tool "shaudmode" loaded.
[20:52:16.855] flashing tool "subarucan" loaded.
[20:52:16.855] flashing tool "mitsucan" loaded.
[20:52:49.038] J2534 API Version: 04.04
[20:52:49.038] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[20:52:49.038] Device Firmware Version: 1.11.3137
[20:52:49.038] Device Serial Number: TAL2Wwkk
[20:52:50.391] kernel get version
[20:52:50.594] interface close
[20:52:50.625] J2534 API Version: 04.04
[20:52:50.625] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[20:52:50.625] Device Firmware Version: 1.11.3137
[20:52:50.625] Device Serial Number: TAL2Wwkk
[20:52:51.077] VIN: JF1GDFKH36G055402
[20:52:51.202] CVN: 35C34F53
[20:52:51.311] interface close
[20:52:51.327] J2534 API Version: 04.04
[20:52:51.327] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[20:52:51.327] Device Firmware Version: 1.11.3137
[20:52:51.327] Device Serial Number: TAL2Wwkk
[20:52:51.499] SSM2 init
[20:52:51.639] SSM2 ECU ID is 4342594006
[20:52:51.717] Requesting Seed...
[20:52:51.764] Sending Key...
[20:52:52.388] interface close
Can anybody tell me what is happening?
please englighten me. thanks to all bros out there.
tanxunhong
Re: Problem with EcuFlash
Postby dt-spd » Sat Nov 19, 2011 11:00 am
did you plug the green connectors under the dash ?
dt-spd
Users browsing this forum: Google [Bot] and 28 guests
