new used ECU, will not flash 04 wrx
Postby cheesy411 » Fri May 20, 2011 9:44 pm
hello everyone,
last week I bricked an ecu, and today the replacement arrived. I went to install it, and the cat started right up with no problem went to drive it if felt like it has hitting a brick wall.. had the peddle floored and it was not moving. I then went ahead, and tried to pull the old map off, and reinstall my stage 2 map.. but with no luck I get this error message through ECU flash
22:02:26.093] Device Firmware Version: 1.10.3020
[22:02:27.656] kernel get version
[22:02:28.031] SSM2 init
[22:02:28.187] SSM2 ECU ID is 2E 14 44 61 06
[22:02:28.281] Requesting Seed...
[22:02:28.328] Sending Key...
[22:02:28.375] interface close
[22:02:28.406] interface close
It will not connect no matter what i do... does anyone have any ideas?
cheesy411
Re: new used ECU, will not flash 04 wrx
Postby eminehart » Sat May 21, 2011 6:15 pm
The ecu is locked. either by ecutek or AP V2 Most likely.
eminehart
Users browsing this forum: No registered users and 18 guests
