radsdau wrote:You could have a marginally low flash voltage, although ECUFlash should warn you if you do. Check the 12V output on the OP cable (OBD pin11 IIRC; beware: Subaru pinouts are not standard). Also check the flash jumper block is ok.
Users browsing this forum: No registered users and 25 guests
