03 Eclipse GTS
03 Eclipse GTS
Postby indyguy699 » Mon Feb 28, 2011 6:59 pm
I have a Mitsubishi Eclipse which I have sucessfully flashed several times.
But now I get this on the ECUFLASH:
[21:49:08.306] J2534 API Version: 04.04
[21:49:08.306] J2534 DLL Version: 0.50.2598 (DEBUG) Jun 26 2009 15:02:29
[21:49:08.306] Device Firmware Version: 1.10.3020
[21:49:10.610] sending init sequence 1 (0001)
[21:49:13.871] sending init sequence 1 (0003)
[21:49:17.131] sending init sequence 1 (FFFF)
[21:49:19.877] no response to any known code
[21:49:19.877] interface close
My car won't start and now it won't read/write to the ecu.
I checked all ecu fuses but nothing was blown.
Also, I am also pretty sure I tried to download a ROM with the car in "acc" not "ON" postion. I know, I'm a dumbass.
Any ideas? Should I check anything or do you think I bricked the ECM?
indyguy699
Re: 03 Eclipse GTS
Postby indyguy699 » Tue Mar 01, 2011 5:31 am
So I figured out that I flashed "0FFF" by accident into the Init section when it should read "0001". Is there anyway for ECUFLASH to try and communicate on "0FFF"?
That is why I can't communicate with the ECM
indyguy699
Re: 03 Eclipse GTS
Postby indyguy699 » Wed Mar 02, 2011 5:56 am
Looks like if anyone has this issue, they can fix it by looking up ECU Unlocker from Malibu Jack on the EVO forums.
Fixed my issue. Init Code is now "0001".
indyguy699
