ecuflash has error but rr logger works...
Postby wrx535 » Sat Jan 29, 2011 8:06 am
Hey guys...
a little insight please...
I can't get ecuflash to work at all... no read, no write no nothing...
I already installed it as administrator and have uninstalled and installed it again already...
here is whats coming out on the task info column..
[23:44:17.180] EcuFlash Version 1.43.3150
[23:44:17.180] OS Version Windows 7
[23:44:17.180] Qt Version 4.6.2
[23:44:17.180] 62 memory models read.
[23:44:17.180] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[23:44:17.570] 354 ROM metadata models scanned.
[23:44:17.570] checksum module "subarudbw" loaded.
[23:44:17.570] checksum module "mitsucan" loaded.
[23:44:17.570] checksum module "mitsuh8" loaded.
[23:44:17.570] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[23:44:17.586] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[23:44:17.586] flashing tool "wrx02" loaded.
[23:44:17.586] flashing tool "wrx04" loaded.
[23:44:17.586] flashing tool "sti04" loaded.
[23:44:17.586] flashing tool "sti05" loaded.
[23:44:17.586] flashing tool "mitsukernel" loaded.
[23:44:17.586] flashing tool "mitsukernelocp" loaded.
[23:44:17.586] flashing tool "mitsubootloader" loaded.
[23:44:17.586] flashing tool "shbootmode" loaded.
[23:44:17.586] flashing tool "shaudmode" loaded.
[23:44:17.586] flashing tool "subarucan" loaded.
[23:44:17.586] flashing tool "mitsucan" loaded.
[23:44:17.586] error loading FTD2XX.DLL
I have a feeling the problem is connected with that last line because that didn't appear in my old laptop..
RR logger connects and logs without any issues...
My new laptop is running windows 7 basic...
I don't know what to do...
Any ideas??
Thanks in advance!
wrx535
Re: ecuflash has error but rr logger works...
Postby radsdau » Sun Jan 30, 2011 3:25 pm
I agree with your diagnosis. OP2 will definitely not work if the J2534 DLL doesn't load. There must have been an issue installing the driver or J2534 software. Try reinstalling with administrative rights, see if that helps.
Postby wrx535 » Sun Jan 30, 2011 10:41 pm
I have done so even from the beginning...
Installed as administrator always...
Actually, 5 times already and its still the same...
I'm clueless... :?: :?:
wrx535
Postby radsdau » Mon Jan 31, 2011 3:18 pm
Strange, sounds like you're doing what I would. See if you can locate the J2534.dll file somewhere and manually put it into the same folder as ECUFlash.exe .
Users browsing this forum: No registered users and 15 guests
