Fist time reflash problems
Postby hitlos » Fri Jan 21, 2011 3:49 am
Machine Lancer 9 Classic 1.6 16v 2008 onwards OpenPort 2.0 orig brought from the U.S. software EcuFlash 1.42. Software sees the lace in the bottom right corner says OpenPort 2.0 (Com4). Open port connected to Wrotham, turn the key to On shake Read from Ecu vibiraem Mitsubishi ALL ACD ECU MH7203FA shake OK wrote J2534 error. All tried to change the type of ECU, tried everything except Subaru, included turning on\off the ignition, resulting in raised 1.43 firmver it updated and is now seen as a port of Open OpenPort 2.0 (USB). With version 1.42 to work become impossible since it does not see the lace, works only 1.43.No 1.43 still does not read the car the same error.
PS ELM 327 diagnostic works good.
hitlos
Re: Fist time reflash problems
Postby radsdau » Sun Jan 23, 2011 3:06 pm
Not sure about 'lancer' (non EVO), but you should probably be using "Mitsubishi EVO9/Eclipse AT" method. Make sure the flash voltage connector is connected (separate connector to OpenPort2 connector. Picture here:
http://www.tactrix.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=24&category_id=6&option=com_virtuemart&Itemid=53)
