EVO ACD reading problem
Postby djdino » Fri Jan 07, 2011 3:14 am
OK have a EVO 9RS and wanted to play with the ACD ECU settings, saw the guys over on EVOM forum were reading etc http://forums.evolutionm.net/ecuflash/473547-break-thru-reading-acd-ecu-ecuflash.html, bought OP2 cable and have been unable to connect to anything. Originally had this log:
[16:00:19.874] EcuFlash Version 1.43.3150
[16:00:19.874] OS Version Windows XP
[16:00:19.874] Qt Version 4.6.2
[16:00:19.889] 62 memory models read.
[16:00:19.889] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[16:00:20.046] 354 ROM metadata models scanned.
[16:00:20.046] checksum module "subarudbw" loaded.
[16:00:20.046] checksum module "mitsucan" loaded.
[16:00:20.046] checksum module "mitsuh8" loaded.
[16:00:20.046] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[16:00:20.046] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[16:00:20.046] flashing tool "wrx02" loaded.
[16:00:20.046] flashing tool "wrx04" loaded.
[16:00:20.046] flashing tool "sti04" loaded.
[16:00:20.046] flashing tool "sti05" loaded.
[16:00:20.046] flashing tool "mitsukernel" loaded.
[16:00:20.046] flashing tool "mitsukernelocp" loaded.
[16:00:20.046] flashing tool "mitsubootloader" loaded.
[16:00:20.046] flashing tool "shbootmode" loaded.
[16:00:20.046] flashing tool "shaudmode" loaded.
[16:00:20.046] flashing tool "subarucan" loaded.
[16:00:20.046] flashing tool "mitsucan" loaded.
[16:00:20.046] error loading FTD2XX.DLL
[16:00:27.592] J2534 API Version: 04.04
[16:00:27.592] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[16:00:27.592] Device Firmware Version: 1.11.3137
[16:00:27.592] Device Serial Number: TA7717yr
[16:00:47.608] sending init sequence 2
[16:00:49.952] J2534 error [ERR_TIMEOUT].
[16:00:50.467] J2534 error [ERR_TIMEOUT].
[16:00:50.467] interface close
but have since loaded the FTD2XX.DLL into the Ecuflash file and this error disappered but still get the J2534 error ?
Have tried:
Uninstall re install ecuflash
Different ACD ECU
Reading Car ECU (wont)
A friends EEE PC with XP SP3, it also crashed
Checked and double checked harness
djdino
Users browsing this forum: Bing [Bot] and 35 guests
