tapki wrote:example.xml
<rom>
<romid>
<xmlid>000000E6</xmlid>
<internalidaddress>f52</internalidaddress>
<internalidhex>000000E6</internalidhex>
<caseid>none</caseid>
<ecuid>none</ecuid>
<make>Mitsubishi</make>
<market>USDM</market>
<model>LancerRalliArt</model>
<submodel>N/A</submodel>
<transmission>Auto</transmission>
<year>2004</year>
<flashmethod>mitsubootloader</flashmethod>
<memmodel>M32176F6</memmodel> *It can't be flashed with M32176F4 correctly (default for RalliArt 512K)
<checksummodule>mitsucan</checksummodule> *Without CHKSUM I've got a CEL and misfires
</romid>
for 1.42 I'm used a file from 1.43.170? beta, becouse of 1.43 crashed in Vista, but under XP everything was fine.
folder: "read templates"
file: read_mitsum32176f6boot.xml :
<rom>
<romid>
<xmlid>read_mitsum32176f6boot</xmlid>
<market>ALL</market>
<model>Colt</model>
<submodel>(768k)</submodel>
<year>2006+?</year>
</romid>
</rom>
I don't read with RA 2004-2006, it won't work for me
I'm used next string "Colt 762K" 2006+ for all 4G69
Mitsiman wrote:The Austrlian 4G69 ECU we sent to you we can read and write back to the ECU, but when we currently write back it bricks the ECU, as for whatever reason, its not writing either the full information back or something similiar to that. I have already had to replace one ECU, Etac controller and ignition barrel / keys on a customer car who was our test vehicle so dont' really want to go through that again. I still have the ECU, Etac and keys from that car in the hopet hat we can bring the ecu back to life again.
Let me know what I can do to provide you in logs etc to show whats happening.
cboles wrote:If someone has an ECU that isn't flashing correctly that they are willing to send it in, I would be happy to fix the problem for them. The problem with a lot of these Mitsu ECUs is that there are slight variations in the bootloader, memory size, erase block size, checksum, etc. between different models that are causing these problems. I think I already have all of the pieces - it just takes some experimentation to get the right combination of a particular ECU. Part of the problem can be fixed by coding on my part - part of the problem will be getting feedback as to what flashing options work with what models so I can put more detailed selections into the read options list.
Marcello wrote:i do them with serial suite piasini it work great
Marcello wrote:ElDominio wrote:Marcello wrote:i do them with serial suite piasini it work great
How does that work?
I looked up the PIasini master suite, you plug the Piasini box directly to the ECU, correct?
And is the map defined? Or do you have to modify it in hex?
the suite is only to read and write ecu the software don't edit i edit in winols
i make the defs directly in winols
