tapki what did you do to make it work?
How your romid section of the definition looks?
Mitsiman wrote:The software is not yet compatible with the 4G69 model lancer vehicles. You are lucky, the first couple we tried we locked the ecu's up and couldn't reflash abck to them.
Your only chance is to go back to a mitsubishi dealer and get the ecu reflashed by them back to stock.
tapki wrote:You should't use a RA interface to read-flash. Start read-flash with Colt 762Kb interface, add checksum module, and have fun.
If you don't have a 762Kb file, convert your firs time read (not after flash) original 512Kb file to 762Kb and edit .xml like for a Colt762Kb.
Everything will be fine.
Also, if you had flashed your ECU with Lancer RA interface, you can't Read it with Colt762Kb interface, becouse the file has changed during flash.
PM me if you need help.
Users browsing this forum: Google [Bot] and 25 guests
