Ecuflash reverting back to old .xml
Postby iTune » Fri Mar 26, 2010 10:45 am
Hello.
I was recently trying to get some code to work in a .xml i was playing around with. I could not get the tables to work properly, so i decided to revert back to my original xml file. Well, Ecuflash is still showing the old messed up tables even though those tables are not defined in the old .xml. i never saved any of my roms while i was doing this, so the problem is with the software it seems. I tried uninstalling Ecuflash several times and it's still doing this.
Is there a way to completly uninstall EcuFlash? Do i need to delete the EcuFlash info in the registry? If so, how?
Thanks for your time.
iTune
Re: Ecuflash reverting back to old .xml
Postby Mojito » Fri Jun 25, 2010 2:30 am
Has this being resolved? I have the same problem. It seems that EcuFlash takes definition xml files no from rommetadata folder, but from somewhere else. When I try to edit xml files, the changes are not reflected when I open a ROM file.
How can fix this?
Mojito
