Cannot Read ECU with V.1.42
Re: Cannot Read ECU with V.1.42
Postby cboles » Fri Jul 16, 2010 7:59 pm
i can see from your screen captures that you have set the directory two levels deeper than you should (..../rommetadata/mitsubishi/eclipse). set it to ..../rommetadata or it won't work properly.
Postby lemmonhead » Sat Jul 17, 2010 10:00 am
I got the correct directory path and I cant read/write either.
look at the bottom of my error, I get a kernel valid, then i get this kernel rsp end.
lemmonhead
Users browsing this forum: No registered users and 3 guests
