help with ecuflash
PostPosted: Fri Nov 13, 2009 5:34 am
by subarutech77
When I try to read a rom image on my 05 subaru outback xt and 05 fxt- I click read image and a blank window opens- read and cancel are at the bottom- read is dull not able to click it- have read roms in the past- tried reinstalling ecuflash and drivers- still had same problem this moring- any ideas?
Re: help with ecuflash
PostPosted: Sat Nov 14, 2009 8:11 pm
by dan az
im having the exact same problem, does anyone ever read these boards?
PostPosted: Sun Nov 15, 2009 7:15 pm
by dan az
i found for some reason that i have to have rom raider and ecuflash installed on the desktop in windows vista, I am running vista home basic on a 24' i-mac. windows sucks.
PostPosted: Mon Nov 16, 2009 5:34 am
by subarutech77
Yeah, im running xp home on a dell mini- the only thing I can think is that Java updated a few days ago- could that be related?- test write works good- kinda afraid to write- just in case something is wrong- I went to try to read a rom on my wife's 05 outback xt and then on my 05 Forester xt in which I successfully read the rom before, but still have the same result- and then I tried to uninstall ecuflash and deleted all the folders and files associated with ecuflash and restarted my system and then redownloaded ecuflash and tried this about 4 times to no avail
PostPosted: Mon Nov 16, 2009 9:07 am
by dan az
when i downloaded ecu flash i had to change the automatic download location from whatever it normally is to the desktop instead, makes no sense to me but it worked,
PostPosted: Mon Nov 16, 2009 11:24 am
by subarutech77
So you are able to read rom from vehicle again?
Ecuflash is working correctly?
PostPosted: Mon Nov 30, 2009 1:45 pm
by pappu
i had the same issue:
here is what i id.
uninstalled it all
installed dot net 1.1 (found around here somewhere)
reinstalled with the cable NOT plugged in
plugged in cable
installed the drivers for that when prompted
then invoke the software
in the read window, made sure to select the model of the vehicle
the read then becomes clickable
worked like a charm!!
PostPosted: Mon Nov 30, 2009 8:24 pm
by subarutech77
Yeah, it was user error on my part- I should have updated sooner- just got it working again the other day- I didn't figure it out until after I reinstalled xp on my computer- no matter, it was getting slow anyways
So here's how I fixed it
I had the metadata directory set as C:/Program Files/OpenECU/EcuFlash/rommetadata/subaru
instead of C:/Program Files/OpenECU/EcuFlash/rommetadata
Now it works properly- if you have it set to a folder inside of the rommetadata folder it will not show the menu to read a rom with the cable hooked up- as long as it's set to the rommetadata folder- it works perfectly
