ECUflash not working, but RomRaider Logger comms work fine..
Postby jblaine » Sat May 09, 2009 3:13 pm
Any ideas? Please? :)
I am trying to flash a 2002 WRX ECU back to stock with a stock ROM.
OpenPort 1.3 cable
ECUflash 1.41
For what it's worth, the logger in RomRaider 0.5.2b for Windows can connect to my ECU... once I selected COM4.
When I connect the green connectors under the dash, turn ignition to ON, and fire up ECUflash to test flash the ROM, I only get the following:
[18:54:56.612] EcuFlash Version 1.41.2483
[18:54:56.612] OS Version Windows XP
[18:54:56.612] Qt Version 4.4.0
[18:54:56.612] 26 memory models read.
[18:54:56.612] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[18:54:56.737] 342 ROM metadata models scanned.
[18:54:56.737] checksum module "subarudbw" loaded.
[18:54:56.737] checksum module "mitsucan" loaded.
[18:54:56.737] flashing tool "wrx02" loaded.
[18:54:56.737] flashing tool "wrx04" loaded.
[18:54:56.737] flashing tool "sti04" loaded.
[18:54:56.737] flashing tool "sti05" loaded.
[18:54:56.737] flashing tool "mitsukernel" loaded.
[18:54:56.737] flashing tool "mitsukernelocp" loaded.
[18:54:56.737] flashing tool "mitsubootloader" loaded.
[18:54:56.737] flashing tool "shbootmode" loaded.
[18:54:56.737] flashing tool "shaudmode" loaded.
[18:54:56.737] flashing tool "subarucan" loaded.
[18:54:56.737] flashing tool "mitsucan" loaded.
[18:55:04.769] A4SGD10C (332 tables) inheriting 16BITBASE (495 tables)
[18:55:04.800] A4SGE01C (3 tables) inheriting A4SGD10C (495 tables)
[18:55:04.831] 163840 byte image read.
[18:55:08.394] Using interface OpenPort 1.3 Subaru TX45akXJ0e84f6d5f39ef0d1c7c4c4a625ac762852c395e3
[18:55:10.472] denso02_bootloader_cmd_start
[18:55:11.706] denso02_bootloader_cmd_start
[18:55:12.940] denso02_bootloader_cmd_start
[18:55:14.159] denso02_bootloader_cmd_start
[18:55:15.394] denso02_bootloader_cmd_start
[18:55:15.831] kernel get version
[18:55:16.159] interface close
I was unable to find a place to specify COM4 in ECUflash (?)
jblaine
Re: ECUflash not working, but RomRaider Logger comms work fine..
Postby jblaine » Sun May 10, 2009 3:11 pm
Okay, I got past that. I was not performing the "IGN ON --> OK click" fast enough.
Test write succeeded.
Real write failed even with full car battery charge (see below). Is there any documentation or FAQ for ECUflash? I'm wandering around in the dark here and running into problems that others surely have encountered.
Any advice?
[18:45:14.487] Using interface OpenPort 1.3 Subaru TX45akXJ0e84f6d5f39ef0d1c7c4c4a625ac762852c395e3
[18:45:19.784] denso02_bootloader_cmd_start
[18:45:20.112] writing kernel area addr: 020000 len: 0664
[18:45:22.050] kernel get version
[18:45:22.065] kernel version is : OpenECU Subaru HC16 Kernel V1.05
[18:45:22.065] reading kernel comm buffer size
[18:45:22.081] comm buffer size set to 512
[18:45:22.081] reading kernel flash buffer size
[18:45:22.097] flash buffer size set to 4096
[18:45:22.097] -- flashing image to ECU memory --
[18:45:22.503] -- comparing ECU flash memory pages to image file --
[18:45:22.503] seg  start    len        ecu CRC32    img CRC32  same?
[18:45:22.815] FB01 00000000 00004000   9E7D9C31     95EECB0A      NO
[18:45:23.144] FB02 00004000 00004000   8F606882     BEC1C9EF      NO
[18:45:23.456] FB03 00008000 00004000   0216DE1B     ED12BFA3      NO
[18:45:23.784] FB04 0000C000 00004000   D3FE83A7     F65FEBBC      NO
[18:45:24.097] FB05 00010000 00004000   3ED4232E     71FA9AE0      NO
[18:45:24.425] FB06 00014000 00004000   9B898AB6     9447808A      NO
[18:45:24.737] FB07 00018000 00004000   939D0A27     DC572A50      NO
[18:45:25.065] FB08 0001C000 00004000   4BE24516     36BC4A8F      NO
[18:45:25.378] FB09 00028000 00004000   C689A482     1BA0DB8A      NO
[18:45:25.706] FB10 0002C000 00004000   20A51562     A532AC32      NO
[18:45:26.003] reading ecu programming voltage
[18:45:26.019] programming voltage is 4.34 volts
[18:45:26.019] programming voltage is out of range!
jblaine
Postby radsdau » Sun May 10, 2009 4:05 pm
Sounds like you don't have the flash jumper block on; this links the 12V programming voltage through to the ECU.
It is possible that the 12V output on the OpenPort cable is dead; I have seen this at least once. I had to replace the 12V low drop-out regulator inside. Check the output pin on the cable with a voltmeter.
Postby jblaine » Sun May 10, 2009 5:56 pm
Thanks (again). I just found the RomRaider FAQ and read the whole thing. So yes, you're right of course, I need the jumper block and don't have it. I'll track one down or order it.
jblaine
Postby jblaine » Tue May 12, 2009 3:03 am
Success!
jblaine
Postby gotsugg » Sun Oct 25, 2009 8:29 pm
I am having a very similar issue, although, as I understand it a 05 LGT does not require a reflash connector. I can log fine but the ECUFlash software just isn’t connecting. I am reading that I should be able to set my comm port. I can set the comm. Port in RR but I don’t see anything listed under “Options” in ECUFlash. Is this something I would have done during set-up? Or am I missing something? Any ideas?
gotsugg
Postby enthusiast » Wed Oct 28, 2009 11:11 pm
gotsugg wrote:I am having a very similar issue, although, as I understand it a 05 LGT does not require a reflash connector. I can log fine but the ECUFlash software just isn’t connecting. I am reading that I should be able to set my comm port. I can set the comm. Port in RR but I don’t see anything listed under “Options” in ECUFlash. Is this something I would have done during set-up? Or am I missing something? Any ideas?
ECUFlash scans for the connection. To flash or read you need to connect the green jumpers on the passenger side floorboard.
enthusiast
