Readback fail...?
Readback fail...?
Postby Tr1s7an » Wed Apr 15, 2009 11:29 am
Hey guys I have an '04 USDM WRX I just recently bought the Openport 2.0 so that I can force emissions readiness on my car. I need an inspection. Anyways, I have the adapter plugged in and the 2 green connectors putting the car into test mode. I start the read within 2 seconds before the fans start up....everything seems to be an order but I get this in the log.
[15:09:02.398] J2534 API Version: 04.04
[15:09:02.398] J2534 DLL Version: 0.50.2464 Jan 29 2009 10:58:58
[15:09:02.398] Device Firmware Version: 1.05.2463
[15:09:03.681] kernel get version
[15:09:04.039] SSM2 init
[15:09:04.200] SSM2 ECU ID is 2E 14 44 61 06
[15:09:04.289] Requesting Seed...
[15:09:04.362] Sending Key...
[15:09:04.412] interface close
[15:09:04.428] interface close
[15:13:30.320] J2534 API Version: 04.04
[15:13:30.320] J2534 DLL Version: 0.50.2464 Jan 29 2009 10:58:58
[15:13:30.320] Device Firmware Version: 1.05.2463
[15:13:32.704] kernel get version
[15:13:32.907] readback fail
[15:13:33.060] SSM2 init
[15:13:33.474] readback fail
[15:13:33.474] SSM2 init
[15:13:33.889] readback fail
[15:13:33.889] SSM2 init
[15:13:34.303] readback fail
[15:13:34.303] SSM2 init
[15:13:34.717] readback fail
[15:13:34.718] SSM2 init
[15:13:35.134] readback fail
[15:13:35.134] SSM2 init
[15:13:35.548] readback fail
[15:13:35.551] SSM2 init
[15:13:35.965] readback fail
[15:13:35.965] SSM2 init
[15:13:36.379] readback fail
[15:13:36.379] SSM2 init
[15:13:36.793] readback fail
[15:13:36.793] SSM2 init
[15:13:37.208] readback fail
[15:13:37.308] interface close
[15:13:37.323] interface close
I'm at a loss....any help would be very appreciated. Thanks in advance.
Tr1s7an
Re: Readback fail...?
Postby radsdau » Wed Apr 15, 2009 2:23 pm
No guarantees, but try one of the earlier WRX hookup methods. You will need the jumper block connected under the dash, as well as the green connectors joined.
Postby Tr1s7an » Thu Apr 16, 2009 11:17 am
I had the green connectors hooked up, and the '04-'05 connector plugged in under the dash. What do you mean by older WRX hook-ups?? Plug in the '01-'03 adapter?
Tr1s7an
Postby merchgod » Thu Apr 16, 2009 12:25 pm
Don't turn on the ignition until prompted to do so and then immediately start the read (as fast as you can - don't wait). Make sure you are selecting the correct read method (should be a USDM 04-05 WRX selection).
merchgod
