Flashing error
Flashing error
Postby project_skyline » Tue Apr 07, 2009 10:37 pm
Well tonight I went to flash some changes onto my evo and it stopped mid way through and gave me the usual error, so i retried and it did the same thing so I save the error log.
[22:08:55.949] EcuFlash Version 1.41.2483
[22:08:55.949] OS Version Windows Vista
[22:08:55.949] Qt Version 4.4.0
[22:08:55.949] 26 memory models read.
[22:08:55.949] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[22:08:56.308] 331 ROM metadata models scanned.
[22:08:56.308] checksum module "subarudbw" loaded.
[22:08:56.308] checksum module "mitsucan" loaded.
[22:08:56.308] flashing tool "wrx02" loaded.
[22:08:56.308] flashing tool "wrx04" loaded.
[22:08:56.308] flashing tool "sti04" loaded.
[22:08:56.308] flashing tool "sti05" loaded.
[22:08:56.308] flashing tool "mitsukernel" loaded.
[22:08:56.308] flashing tool "mitsukernelocp" loaded.
[22:08:56.308] flashing tool "mitsubootloader" loaded.
[22:08:56.308] flashing tool "shbootmode" loaded.
[22:08:56.308] flashing tool "shaudmode" loaded.
[22:08:56.308] flashing tool "subarucan" loaded.
[22:08:56.308] flashing tool "mitsucan" loaded.
[22:09:04.980] 94170015 (100 tables) inheriting evo7base (73 tables)
[22:09:04.980] 262144 byte image read.
[22:09:08.426] Using interface OpenPort 1.3 Universal TX27n8QN61acb4d9e1166ee281fe9032b57cbd6c7aafe5f4
[22:09:10.408] sending init sequence 1 (0001)
[22:09:13.626] sending init sequence 1 (0003)
[22:09:16.845] sending init sequence 1 (FFFF)
[22:09:17.861] got 0x05 response
[22:09:17.861] sending init sequence 2
[22:09:17.861] got 0x1B response
[22:09:17.861] sending init sequence 3
[22:09:18.251] entering bootloader
[22:09:18.251] sending kernel size (3560)
[22:09:18.251] sending kernel load address (0xFFFF8800)
[22:09:18.267] uploading kernel
[22:09:18.845] verifying kernel checksum response
[22:09:18.845] kernel valid
[22:09:19.048] kernel get version
[22:09:19.064] kernel version is : OpenECU Mitsubishi SH7052 Kernel V1.06
[22:09:19.064] reading kernel comm buffer size
[22:09:19.079] comm buffer size set to 512
[22:09:19.079] reading kernel flash buffer size
[22:09:19.095] flash buffer size set to 4096
[22:09:19.095] -- flashing image to ECU memory --
[22:09:19.501] -- comparing ECU flash memory pages to image file --
[22:09:19.501] seg start len ecu CRC32 img CRC32 same?
[22:09:19.517] FB01 00000000 00001000 CAA997E2 CAA997E2 YES
[22:09:19.533] FB02 00001000 00001000 AF8EB452 AF8EB452 YES
[22:09:19.564] FB03 00002000 00001000 2A848F39 2A848F39 YES
[22:09:19.579] FB04 00003000 00001000 E11E7E0A AE3C3A74 NO
[22:09:19.611] FB05 00004000 00001000 8952C528 A2661C6B NO
[22:09:19.626] FB06 00005000 00001000 FFEDA26A FFEDA26A YES
[22:09:19.642] FB07 00006000 00001000 3D290937 3D290937 YES
[22:09:19.673] FB08 00007000 00001000 2A8CF5E9 2A8CF5E9 YES
[22:09:19.767] FB09 00008000 00008000 8B6B957F 8B6B957F YES
[22:09:19.970] FB10 00010000 00010000 4BCDC4EA 4BCDC4EA YES
[22:09:20.236] FB11 00020000 00010000 3EB5B1CF 3EB5B1CF YES
[22:09:20.439] FB12 00030000 00010000 DEAB7E4E EAD74FD8 NO
[22:09:20.439] kernel flash enable
[22:09:20.439] kernel blank flash page: addr: 00030000
[22:09:20.501] erased in 2 pulse(s)
[22:09:20.501] kernel write flash buffer addr: 00030000 len: 00000200
[22:09:20.595] kernel write flash buffer addr: 00030200 len: 00000200
[22:09:20.689] kernel write flash buffer addr: 00030400 len: 00000200
[22:09:20.783] kernel write flash buffer addr: 00030600 len: 00000200
[22:09:20.892] kernel write flash buffer addr: 00030800 len: 00000200
[22:09:20.986] kernel write flash buffer addr: 00030A00 len: 00000200
[22:09:21.079] kernel write flash buffer addr: 00030C00 len: 00000200
[22:09:21.236] kernel write flash buffer addr: 00030E00 len: 00000200
[22:09:21.329] kernel commit flash addr: 00030000 len: 00001000 crc32 78fe7ac0
[22:09:21.939] written in 76 pulse(s)
[22:09:21.939] kernel write flash buffer addr: 00031000 len: 00000200
[22:09:22.048] kernel write flash buffer addr: 00031200 len: 00000200
[22:09:22.142] kernel write flash buffer addr: 00031400 len: 00000200
[22:09:24.329] readback fail
[22:09:24.345] reading kernel comm stats
[22:09:24.408] readback mismatch
[22:09:24.408] kernel write flash buffer addr: 00031400 len: 00000200
[22:09:24.486] readback mismatch
[22:09:24.486] reading kernel comm stats
[22:09:24.486] kernel write flash buffer addr: 00031400 len: 00000200
[22:09:24.564] readback mismatch
[22:09:24.564] reading kernel comm stats
[22:09:24.564] kernel write flash buffer addr: 00031400 len: 00000200
[22:09:24.658] readback mismatch
[22:09:24.673] reading kernel comm stats
[22:09:24.673] readback mismatch
[22:09:24.673] kernel write flash buffer addr: 00031400 len: 00000200
[22:09:24.736] readback mismatch
[22:09:24.736] reading kernel comm stats
[22:09:24.751] kernel write flash buffer addr: 00031400 len: 00000200
[22:09:24.829] readback mismatch
[22:09:24.829] reading kernel comm stats
[22:09:24.829] failure in flashing block
[22:09:24.829] kernel flash disable
[22:09:24.829] interface close
[22:13:14.266] Using interface OpenPort 1.3 Universal TX27n8QN61acb4d9e1166ee281fe9032b57cbd6c7aafe5f4
[22:13:22.362] sending init sequence 1 (FFFF)
[22:13:23.378] got 0x05 response
[22:13:23.378] sending init sequence 2
[22:13:23.378] got 0x1B response
[22:13:23.378] sending init sequence 3
[22:13:23.769] entering bootloader
[22:13:23.769] sending kernel size (3560)
[22:13:23.800] sending kernel load address (0xFFFF8800)
[22:13:23.816] uploading kernel
[22:13:26.503] readback fail
[22:13:26.503] error transmitting kernel
[22:13:26.503] interface close
[22:13:47.857] Using interface OpenPort 1.3 Universal TX27n8QN61acb4d9e1166ee281fe9032b57cbd6c7aafe5f4
[22:13:50.329] sending init sequence 1 (FFFF)
[22:13:51.345] got 0x05 response
[22:13:51.345] sending init sequence 2
[22:13:51.345] got 0x1B response
[22:13:51.345] sending init sequence 3
[22:13:51.735] entering bootloader
[22:13:51.735] sending kernel size (3560)
[22:13:51.767] sending kernel load address (0xFFFF8800)
[22:13:51.782] uploading kernel
[22:13:54.501] readback fail
[22:13:54.501] error transmitting kernel
[22:13:54.501] interface close
[22:14:07.754] Using interface OpenPort 1.3 Universal TX27n8QN61acb4d9e1166ee281fe9032b57cbd6c7aafe5f4
[22:14:10.227] sending init sequence 1 (FFFF)
[22:14:11.243] got 0x05 response
[22:14:11.243] sending init sequence 2
[22:14:11.243] got 0x1B response
[22:14:11.243] sending init sequence 3
[22:14:11.696] entering bootloader
[22:14:11.696] sending kernel size (3560)
[22:14:11.727] sending kernel load address (0xFFFF8800)
[22:14:11.743] uploading kernel
[22:14:12.352] verifying kernel checksum response
[22:14:12.368] kernel valid
[22:14:12.571] kernel get version
[22:14:12.587] kernel version is : OpenECU Mitsubishi SH7052 Kernel V1.06
[22:14:12.587] reading kernel comm buffer size
[22:14:12.587] comm buffer size set to 512
[22:14:12.587] reading kernel flash buffer size
[22:14:12.602] flash buffer size set to 4096
[22:14:12.602] -- dumping ECU memory --
[22:14:12.618] kernel read area: addr: 00000000 len: 0200
[22:14:12.712] kernel read area: addr: 00000200 len: 0200
[22:14:12.805] kernel read area: addr: 00000400 len: 0200
[22:14:12.899] kernel read area: addr: 00000600 len: 0200
[22:14:12.993] kernel read area: addr: 00000800 len: 0200
[22:14:13.102] kernel read area: addr: 00000A00 len: 0200
[22:14:13.196] kernel read area: addr: 00000C00 len: 0200
[22:14:13.352] kernel read area: addr: 00000E00 len: 0200
[22:14:13.462] kernel read area: addr: 00001000 len: 0200
[22:14:13.555] kernel read area: addr: 00001200 len: 0200
[22:14:13.649] kernel read area: addr: 00001400 len: 0200
[22:14:13.743] kernel read area: addr: 00001600 len: 0200
[22:14:13.837] kernel read area: addr: 00001800 len: 0200
[22:14:13.930] kernel read area: addr: 00001A00 len: 0200
[22:14:14.024] kernel read area: addr: 00001C00 len: 0200
[22:14:14.118] kernel read area: addr: 00001E00 len: 0200
[22:14:14.227] kernel read area: addr: 00002000 len: 0200
[22:14:14.352] kernel read area: addr: 00002200 len: 0200
[22:14:14.446] kernel read area: addr: 00002400 len: 0200
[22:14:14.524] kernel read area: addr: 00002600 len: 0200
[22:14:14.618] kernel read area: addr: 00002800 len: 0200
[22:14:14.712] kernel read area: addr: 00002A00 len: 0200
[22:14:14.805] kernel read area: addr: 00002C00 len: 0200
[22:14:14.899] kernel read area: addr: 00002E00 len: 0200
[22:14:15.009] kernel read area: addr: 00003000 len: 0200
[22:14:15.102] kernel read area: addr: 00003200 len: 0200
[22:14:15.196] kernel read area: addr: 00003400 len: 0200
[22:14:15.352] kernel read area: addr: 00003600 len: 0200
[22:14:15.446] kernel read area: addr: 00003800 len: 0200
[22:14:15.540] kernel read area: addr: 00003A00 len: 0200
[22:14:15.634] kernel read area: addr: 00003C00 len: 0200
[22:14:15.727] kernel read area: addr: 00003E00 len: 0200
[22:14:15.837] kernel read area: addr: 00004000 len: 0200
[22:14:15.930] kernel read area: addr: 00004200 len: 0200
[22:14:16.024] kernel read area: addr: 00004400 len: 0200
[22:14:16.118] kernel read area: addr: 00004600 len: 0200
[22:14:16.212] kernel read area: addr: 00004800 len: 0200
[22:14:16.352] kernel read area: addr: 00004A00 len: 0200
[22:14:16.446] kernel read area: addr: 00004C00 len: 0200
[22:14:16.540] kernel read area: addr: 00004E00 len: 0200
[22:14:16.649] kernel read area: addr: 00005000 len: 0200
[22:14:16.743] kernel read area: addr: 00005200 len: 0200
[22:14:16.837] kernel read area: addr: 00005400 len: 0200
[22:14:16.930] kernel read area: addr: 00005600 len: 0200
[22:14:17.024] kernel read area: addr: 00005800 len: 0200
[22:14:17.118] kernel read area: addr: 00005A00 len: 0200
[22:14:17.212] kernel read area: addr: 00005C00 len: 0200
[22:14:17.352] kernel read area: addr: 00005E00 len: 0200
[22:14:17.462] kernel read area: addr: 00006000 len: 0200
[22:14:17.555] kernel read area: addr: 00006200 len: 0200
[22:14:17.649] kernel read area: addr: 00006400 len: 0200
[22:14:17.743] kernel read area: addr: 00006600 len: 0200
[22:14:17.837] kernel read area: addr: 00006800 len: 0200
[22:14:17.930] kernel read area: addr: 00006A00 len: 0200
[22:14:18.024] kernel read area: addr: 00006C00 len: 0200
[22:14:18.118] kernel read area: addr: 00006E00 len: 0200
[22:14:18.227] kernel read area: addr: 00007000 len: 0200
[22:14:18.352] kernel read area: addr: 00007200 len: 0200
[22:14:18.446] kernel read area: addr: 00007400 len: 0200
[22:14:18.524] kernel read area: addr: 00007600 len: 0200
[22:14:18.618] kernel read area: addr: 00007800 len: 0200
[22:14:18.712] kernel read area: addr: 00007A00 len: 0200
[22:14:18.805] kernel read area: addr: 00007C00 len: 0200
[22:14:18.884] kernel read area: addr: 00007E00 len: 0200
[22:14:19.009] kernel read area: addr: 00008000 len: 0200
[22:14:19.102] kernel read area: addr: 00008200 len: 0200
[22:14:19.180] kernel read area: addr: 00008400 len: 0200
[22:14:19.290] kernel read area: addr: 00008600 len: 0200
[22:14:21.493] rkrv: kernel response incomplete
[22:14:21.493] invalid / no kernel response to read
[22:14:21.493] ECU memory read failure.
[22:14:21.493] can't read image.
[22:14:21.493] interface close
Im going to try a few things in the morning but maybe someone can help me out.
Im using version 1.41
project_skyline
Re: Flashing error
Postby radsdau » Wed Apr 08, 2009 3:25 pm
EVOs should always be reflashable after a failed reflash; there is a bootloader that never (realistically) gets erased.
Check connections, battery levels, and PC performance.
