reflashing > is it that simple?
Postby wrxsti » Sun Apr 02, 2006 1:21 am
Hi all.
I have a basic question which I would like to know before wrecking a ecu.
Using Ecu explorer, I have read the ECU flash memory of a friend's EUR MY05 WRX with PPP. (..cpu.hex and ..tpu.hex file)
Can I use these files to simply upload these using "write rom image to ecu flash memory" in a standard MY05 WRX to give it PPP?
If yes, do I only need to upload the ..cpu.hex or also the tpu.hex?
Many Thanks in advance guys!
P.S. If this is the case and anyone is interested in a "cc" of the PPP ecu file, let me know! :wink:
wrxsti
Postby Edward » Sun Apr 02, 2006 9:35 am
A couple of suggestions:
Are both the ECU's the same model number?
Make sure you read and save the non PPP ECU before flashing it - that way you can always put it back to normal.
Are you in the uK?
Cheers
Edward.
Edward
Postby TypeC » Wed Apr 19, 2006 12:46 pm
What is PPP?
TypeC
Postby xswrex » Wed Apr 19, 2006 10:21 pm
P**drive Performance Pack :wink:
xswrex
Users browsing this forum: No registered users and 33 guests
