Unable to read programming voltage?
Postby qbanrex » Fri May 18, 2007 4:56 pm
Was this problem ever solved ???? I am expriencing the same problem now... HELP :cry:
qbanrex
Postby Hyper » Sat May 19, 2007 4:31 pm
me too
Hyper
Postby fljason » Fri Jun 01, 2007 4:20 pm
im having the same problem anyone get a fix yet
fljason
fljason
Postby PRR_INC » Fri Sep 28, 2007 6:34 am
Same issue here. on an 02 WRX. Used to flash fine, now it can't read the voltage. Will check the connector voltage and reset the ECU via power off and report back.
Is there a way to test the Tactrix (sp?) cable off the car by providing 12v to the correct pins and testing the voltage via software?
Jason
PRR_INC
Postby PRR_INC » Mon Oct 01, 2007 8:54 am
Turns out I've been a complete sped. Was attempting to use the ecuflash embedded into an old version of Ecu Explorer. Used an updated version of ecu flash and it worked just fine.
Jason
PRR_INC
