Flashing a map in a different ecu
Postby xav » Thu Dec 25, 2008 3:13 pm
Is it possible to scribe with Ecuflash a JDM sti map (A4TJ111B) for exemple in a 16b EDM sti ecu ?
xav
Re: Flashing a map in a different ecu
Postby ®@©E® » Sat Dec 27, 2008 3:37 am
I started similar thread on RomRaider, but forum seems to be down now, so I can't give you a link. Short answer, you can flash any rom with same flash method, car would probably start and tere would be CELs, sometimes a lot
®@©E®
Postby AlGontsov » Sat Dec 27, 2008 10:15 pm
You must open an original ROM and make the same chenges in the corresponded fields or use copy-paste from one to another if x and y axis of maps are equal. And then it should be work.
Of course flashing another ROM to ECU can bring a lot of troubles ;)
AlGontsov
Users browsing this forum: Google [Bot] and 30 guests
