06 sti Read errors (Bad checksum) version 1.40 ecuflash
Postby 3gsucks » Sun Nov 23, 2008 12:38 pm
I was reading the ecu on my buddies 2006 Sti and the log continued to give me bad checksum errors in the read. I was still able to test write and write to the ecu fine and also completed the read successfully after a couple tries.
my 06 wrx on the older version has never given my a problem i just recently downloaded the newest version. I also was able to read my ecu without any errors on the 1.40 version.
im just not sure what causes these error so anyone with the knowledge to enlighten me that would be great.
here is part of the log showing the errors and where they occurred.
[18:37:24.609] Version 1.40.2178
[18:37:24.625] 19 memory models read.
[18:37:24.625] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[18:37:24.859] 319 ROM metadata models scanned.
[18:37:24.859] checksum module "subarudbw" loaded.
[18:37:24.859] flashing tool "wrx02" loaded.
[18:37:24.859] flashing tool "wrx04" loaded.
[18:37:24.859] flashing tool "sti04" loaded.
[18:37:24.859] flashing tool "sti05" loaded.
[18:37:24.859] flashing tool "mitsukernel" loaded.
[18:37:24.859] flashing tool "mitsukernelocp" loaded.
[18:37:24.859] flashing tool "shbootmode" loaded.
[18:37:24.859] flashing tool "shaudmode" loaded.
[18:37:24.859] flashing tool "subarucan" loaded.
[18:37:43.187] Using interface OpenPort 1.3 Subaru TX4592Dm2144f6c914e91698de6c3289ea9d25d750e713e9
[18:37:47.453] kernel get version
[18:37:47.843] SSM2 init
[18:37:48.000] SSM2 ECU ID is 43 12 59 40 06
[18:37:48.093] Requesting Seed...
[18:37:48.156] Sending Key...
[18:37:48.781] writing kernel area addr: FFFF3000 len: 0CF4
[18:37:48.796] SSM2 write kernel ram block addr: FFFF3000 len: 0080
[18:37:48.890] SSM2 write kernel ram block addr: FFFF3080 len: 0080
[18:37:49.000] SSM2 write kernel ram block addr: FFFF3100 len: 0080
[18:37:49.109] SSM2 write kernel ram block addr: FFFF3180 len: 0080
[18:37:49.218] SSM2 write kernel ram block addr: FFFF3200 len: 0080
[18:37:49.312] SSM2 write kernel ram block addr: FFFF3280 len: 0080
[18:37:49.421] SSM2 write kernel ram block addr: FFFF3300 len: 0080
[18:37:49.531] SSM2 write kernel ram block addr: FFFF3380 len: 0080
[18:37:49.625] SSM2 write kernel ram block addr: FFFF3400 len: 0080
[18:37:49.734] SSM2 write kernel ram block addr: FFFF3480 len: 0080
[18:37:49.828] SSM2 write kernel ram block addr: FFFF3500 len: 0080
[18:37:49.937] SSM2 write kernel ram block addr: FFFF3580 len: 0080
[18:37:50.031] SSM2 write kernel ram block addr: FFFF3600 len: 0080
[18:37:50.140] SSM2 write kernel ram block addr: FFFF3680 len: 0080
[18:37:50.250] SSM2 write kernel ram block addr: FFFF3700 len: 0080
[18:37:50.343] SSM2 write kernel ram block addr: FFFF3780 len: 0080
[18:37:50.453] SSM2 write kernel ram block addr: FFFF3800 len: 0080
[18:37:50.578] SSM2 write kernel ram block addr: FFFF3880 len: 0080
[18:37:50.687] SSM2 write kernel ram block addr: FFFF3900 len: 0080
[18:37:50.796] SSM2 write kernel ram block addr: FFFF3980 len: 0080
[18:37:50.906] SSM2 write kernel ram block addr: FFFF3A00 len: 0080
[18:37:51.031] SSM2 write kernel ram block addr: FFFF3A80 len: 0080
[18:37:51.140] SSM2 write kernel ram block addr: FFFF3B00 len: 0080
[18:37:51.234] SSM2 write kernel ram block addr: FFFF3B80 len: 0080
[18:37:51.359] SSM2 write kernel ram block addr: FFFF3C00 len: 0080
[18:37:51.468] SSM2 write kernel ram block addr: FFFF3C80 len: 0074
[18:37:52.015] kernel get version
[18:37:52.015] kernel version is : OpenECU Subaru SH7058 OCP Kernel V1.05
[18:37:52.015] reading kernel comm buffer size
[18:37:52.031] comm buffer size set to 512
[18:37:52.031] reading kernel flash buffer size
[18:37:52.046] flash buffer size set to 4096
[18:37:52.046] -- dumping ECU memory --
[18:37:52.093] kernel read area: addr: 00000000 len: 0200
[18:37:52.203] kernel read area: addr: 00000200 len: 0200
[18:37:52.296] kernel read area: addr: 00000400 len: 0200
[18:37:52.390] kernel read area: addr: 00000600 len: 0200
[18:37:52.500] kernel read area: addr: 00000800 len: 0200
[18:37:52.609] kernel read area: addr: 00000A00 len: 0200
[18:37:52.703] kernel read area: addr: 00000C00 len: 0200
[18:37:52.796] rkrv: bad checksum
[18:37:52.812] invalid kernel response - retrying
[18:37:52.921] rkrv: bad checksum
[18:37:52.937] invalid kernel response - retrying
[18:37:53.031] kernel read area: addr: 00000E00 len: 0200
[18:37:53.156] kernel read area: addr: 00001000 len: 0200
[18:37:53.265] kernel read area: addr: 00001200 len: 0200
[18:37:53.359] kernel read area: addr: 00001400 len: 0200
[18:37:53.453] kernel read area: addr: 00001600 len: 0200
[18:37:53.546] kernel read area: addr: 00001800 len: 0200
[18:37:53.640] kernel read area: addr: 00001A00 len: 0200
[18:37:53.750] kernel read area: addr: 00001C00 len: 0200
[18:37:53.843] kernel read area: addr: 00001E00 len: 0200
[18:37:53.968] kernel read area: addr: 00002000 len: 0200
[18:37:54.062] kernel read area: addr: 00002200 len: 0200
[18:37:54.171] kernel read area: addr: 00002400 len: 0200
[18:37:54.281] kernel read area: addr: 00002600 len: 0200
[18:37:54.390] kernel read area: addr: 00002800 len: 0200
[18:37:54.468] kernel read area: addr: 00002A00 len: 0200
[18:37:54.562] kernel read area: addr: 00002C00 len: 0200
[18:37:54.656] kernel read area: addr: 00002E00 len: 0200
[18:37:54.765] kernel read area: addr: 00003000 len: 0200
3gsucks
Postby radsdau » Sun Nov 23, 2008 4:41 pm
Wow, I've never seen that before. At least the code is catching the errors, retrying, and obtaining a successful read eventually.
Perhaps the cable is patchy, or the pin connections? How's the battery voltage?
Postby 3gsucks » Sun Nov 23, 2008 11:29 pm
well the funny thing is the same cable was able to flash the car without reconnecting it with no errors.
I was also able to read my car with no errors.
I did not check the voltage. His car has a viper alarm could that cause any problems?
3gsucks
Postby radsdau » Mon Nov 24, 2008 3:28 pm
It is possible the alarm is accessing the comms line and any extra load on it may alter the shape of the bits, which *could* lead to the occasional read error. That's what the checksum is all about. :)
Postby 3gsucks » Mon Nov 24, 2008 7:26 pm
Ok, so it probably is the alarm then cause i want to say the time i got it do read without any errors the alarm system was i believe turned off. We did a hard reset and I think i remember him turning off the alarm so we could do that.
also although this has never happened if an error occurs during flash, as long as the ecu stays powered and in test mod i can continue to retry flashing. Can i unplug and plug back in the cable?
Btw Thanks for the Help
Nick
3gsucks
Postby radsdau » Tue Nov 25, 2008 8:30 pm
3gsucks wrote:also although this has never happened if an error occurs during flash, as long as the ecu stays powered and in test mod i can continue to retry flashing. Can i unplug and plug back in the cable?
Yes that should be ok. (Not so with an EVO though)
3gsucks wrote:Btw Thanks for the Help
np :)
Re: 06 sti Read errors (Bad checksum) version 1.40 ecuflash
Postby 3gsucks » Thu Jan 01, 2009 10:43 pm
Just an update I tuned another 06 sti different car, but it also had the same viper alarm system on it.
This car too had the same problem with bad checksums in the read and also For the first time gave me error's during the Final Flash after completing a test write.
The ecu had a partial flash on the car and was hung up for a couple minute, it took maybe 10 tries before it finally completed a successful flash.
This car had never been flashed before, I was putting on a stage 2 tune with some cel deleted and also had the checksum fix put on it. after it failed to flash the New stage 2 rom image i tried to flash the stock map back and that instantly failed.
I though for sure i had bricked the ecu I had never seen the error message that had popped up when it failed.
I dont know if this is because im using a newer version or if the older versions did the samething.
here is the log i tried to cut out as much of the un important stuff as possible
[14:18:11.375] kernel write flash buffer addr: 00063000 len: 00000200
[14:18:11.453] kernel write flash buffer addr: 00063200 len: 00000200
[14:18:11.546] kernel write flash buffer addr: 00063400 len: 00000200
[14:18:11.656] kernel write flash buffer addr: 00063600 len: 00000200
[14:18:11.750] kernel write flash buffer addr: 00063800 len: 00000200
[14:18:11.843] kernel write flash buffer addr: 00063A00 len: 00000200
[14:18:11.953] kernel write flash buffer addr: 00063C00 len: 00000200
[14:18:12.062] kernel write flash buffer addr: 00063E00 len: 00000200
[14:18:12.171] kernel commit flash addr: 00063000 len: 00001000 crc32 8ed921a4
[14:18:12.203] rkrv: bad checksum
[14:18:12.203] failed to commit flash at 00063000!
[14:18:12.203] failure in flashing block
[14:18:12.203] kernel flash disable
[14:18:12.234] interface close
[14:18:12.250] interface close
[14:18:26.187] Using interface OpenPort 1.3 Subaru TX4592Dm2144f6c914e91698de6c3289ea9d25d750e713e9
[14:18:27.593] kernel get version
[14:18:27.593] kernel already resident - skipping kernel load
[14:18:27.812] kernel get version
[14:18:27.828] kernel version is : OpenECU Subaru SH7058 OCP Kernel V1.05
[14:18:27.828] reading kernel comm buffer size
[14:18:27.843] comm buffer size set to 512
[14:18:27.843] reading kernel flash buffer size
[14:18:27.843] flash buffer size set to 4096
[14:18:27.843] -- flashing image to ECU memory --
[14:18:28.250] -- comparing ECU flash memory pages to image file --
[14:18:28.250] seg start len ecu CRC32 img CRC32 same?
[14:18:28.265] FB01 00000000 00001000 29450393 29450393 YES
[14:18:28.281] FB02 00001000 00001000 8F101821 8F101821 YES
[14:18:28.312] FB03 00002000 00001000 B444A26D B444A26D YES
[14:18:49.343] kernel commit flash addr: 00073000 len: 00001000 crc32 4a21fa9e
[14:18:49.406] written in 1 pulse(s)
[14:18:49.406] kernel write flash buffer addr: 00074000 len: 00000200
[14:18:49.500] kernel write flash buffer addr: 00074200 len: 00000200
[14:18:49.593] kernel write flash buffer addr: 00074400 len: 00000200
[14:18:49.703] kernel write flash buffer addr: 00074600 len: 00000200
[14:18:49.812] kernel write flash buffer addr: 00074800 len: 00000200
[14:18:49.906] kernel write flash buffer addr: 00074A00 len: 00000200
[14:18:50.015] kernel write flash buffer addr: 00074C00 len: 00000200
[14:18:50.125] kernel write flash buffer addr: 00074E00 len: 00000200
[14:18:50.203] kernel commit flash addr: 00074000 len: 00001000 crc32 58b1563a
[14:18:50.265] written in 1 pulse(s)
[14:18:50.281] kernel write flash buffer addr: 00075000 len: 00000200
[14:18:50.390] kernel write flash buffer addr: 00075200 len: 00000200
[14:18:50.500] kernel write flash buffer addr: 00075400 len: 00000200
[14:18:50.609] kernel write flash buffer addr: 00075600 len: 00000200
[14:18:50.718] kernel write flash buffer addr: 00075800 len: 00000200
[14:18:50.812] kernel write flash buffer addr: 00075A00 len: 00000200
[14:18:50.921] kernel write flash buffer addr: 00075C00 len: 00000200
[14:18:51.031] kernel write flash buffer addr: 00075E00 len: 00000200
[14:18:51.140] kernel commit flash addr: 00075000 len: 00001000 crc32 733a649e
[14:18:51.187] written in 1 pulse(s)
000 crc32 d5caca45
[14:18:52.968] written in 1 pulse(s)
[14:18:52.984] kernel write flash buffer addr: 00078000 len: 00000200
[14:18:53.093] kernel write flash buffer addr: 00078200 len: 00000200
[14:18:53.203] kernel write flash buffer addr: 00078400 len: 00000200
[14:18:53.312] rkrv: preamble 1 error
[14:18:53.328] kernel write flash buffer addr: 00078400 len: 00000200
[14:18:53.421] readback mismatch
[14:18:53.437] kernel write flash buffer addr: 00078400 len: 00000200
[14:18:53.546] readback mismatch
[14:18:53.562] failure in flashing block
[14:18:53.562] kernel flash disable
[14:18:53.562] readback mismatch
[14:18:53.562] interface close
[14:19:01.093] Using interface OpenPort 1.3 Subaru TX4592Dm2144f6c914e91698de6c3289ea9d25d750e713e9
[14:19:02.515] kernel get version
[14:19:02.531] kernel already resident - skipping kernel load
[14:19:02.750] kernel get version
[14:19:02.750] kernel version is : OpenECU Subaru SH7058 OCP Kernel V1.05
[14:19:02.765] reading kernel comm buffer size
[14:19:02.765] comm buffer size set to 512
[14:19:02.781] reading kernel flash buffer size
[14:19:02.781] flash buffer size set to 4096
[14:19:02.781] -- flashing image to ECU memory --
[14:19:03.187] -- comparing ECU flash memory pages to image file --
[14:19:03.187] seg start len ecu CRC32 img CRC32 same?
[14:19:03.203] FB01 00000000 00001000 29450393 29450393 YES
[14:19:03.218] FB02 00001000 00001000 8F101821 8F101821 YES
[14:19:03.265] FB03 00002000 00001000 B444A26D B444A26D YES
[14:19:03.281] FB04 00003000 00001000 104341C4 104341C4 YES
[14:19:03.312] FB05 00004000 00001000 EBCDD9C9 EBCDD9C9 YES
[14:19:03.328] FB06 00005000 00001000 7E3DAFE5 7E3DAFE5 YES
[14:19:03.343] FB07 00006000 00001000 91165354 91165354 YES
[14:19:03.375] FB08 00007000 00001000 064EA404 064EA404 YES
[14:19:03.625] FB09 00008000 00018000 1CD5C3EF 1CD5C3EF YES
[14:19:03.968] FB10 00020000 00020000 C54810DF C54810DF YES
[14:19:04.296] FB11 00040000 00020000 9B4BE434 9B4BE434 YES
[14:19:04.640] FB12 00060000 00020000 F98809BC 786FE25F NO
[14:19:04.984] FB13 00080000 00020000 154803CC 154803CC YES
[14:19:05.328] FB14 000A0000 00020000 154803CC 154803CC YES
[14:19:05.656] FB15 000C0000 00020000 4C8E2203 4C8E2203 YES
[14:19:06.015] FB16 000E0000 00020000 18A52C21 18A52C21 YES
[14:19:06.031] kernel flash enable
[14:19:06.062] kernel blank flash page: addr: 00060000
[14:19:08.031] erased in 1 pulse(s)
0007A200 len: 00000200
[14:19:31.359] kernel write flash buffer addr: 0007A400 len: 00000200
[14:19:31.453] kernel write flash buffer addr: 0007A600 len: 00000200
[14:19:31.546] kernel write flash buffer addr: 0007A800 len: 00000200
[14:19:31.656] rkrv: preamble 1 error
[14:19:31.671] kernel write flash buffer addr: 0007A800 len: 00000200
[14:19:31.781] readback mismatch
[14:19:31.796] kernel write flash buffer addr: 0007A800 len: 00000200
[14:19:31.890] readback mismatch
[14:19:31.906] failure in flashing block
[14:19:31.906] kernel flash disable
[14:19:31.906] readback mismatch
[14:19:31.906] interface close
[14:19:39.078] 1048576 byte image read.
[14:19:47.796] Using interface OpenPort 1.3 Subaru TX4592Dm2144f6c914e91698de6c3289ea9d25d750e713e9
[14:19:49.203] kernel get version
[14:19:49.203] kernel already resident - skipping kernel load
[14:19:49.421] kernel get version
[14:19:49.421] kernel version is : OpenECU Subaru SH7058 OCP Kernel V1.05
[14:19:49.421] reading kernel comm buffer size
[14:19:49.437] comm buffer size set to 512
[14:19:49.437] reading kernel flash buffer size
[14:19:49.453] rkrv: bad checksum
[14:19:49.453] interface close
[14:19:54.312] Using interface OpenPort 1.3 Subaru TX4592Dm2144f6c914e91698de6c3289ea9d25d750e713e9
[14:19:55.671] kernel get version
[14:19:55.671] kernel already resident - skipping kernel load
[14:19:55.890] kernel get version
[14:19:55.890] kernel version is : OpenECU Subaru SH7058 OCP Kernel V1.05
[14:19:55.890] reading kernel comm buffer size
[14:19:55.906] comm buffer size set to 512
[14:19:55.906] reading kernel flash buffer size
[14:19:55.921] flash buffer size set to 4096
[14:19:55.921] -- flashing image to ECU memory --
[14:19:56.328] -- comparing ECU flash memory pages to image file --
[14:19:56.328] seg start len ecu CRC32 img CRC32 same?
[14:19:56.343] FB01 00000000 00001000 29450393 29450393 YES
[14:19:56.359] FB02 00001000 00001000 8F101821 8F101821 YES
[14:19:56.390] FB03 00002000 00001000 B444A26D B444A26D YES
[14:19:56.406] FB04 00003000 00001000 104341C4 104341C4 YES
[14:19:56.437] FB05 00004000 00001000 EBCDD9C9 EBCDD9C9 YES
[14:19:56.453] FB06 00005000 00001000 7E3DAFE5 7E3DAFE5 YES
[14:19:56.484] FB07 00006000 00001000 91165354 91165354 YES
[14:19:56.500] FB08 00007000 00001000 064EA404 064EA404 YES
[14:19:56.750] FB09 00008000 00018000 1CD5C3EF 1CD5C3EF YES
[14:19:57.093] FB10 00020000 00020000 C54810DF C54810DF YES
[14:19:57.421] FB11 00040000 00020000 9B4BE434 9B4BE434 YES
[14:19:57.765] FB12 00060000 00020000 E1B77DB7 9B93A7E7 NO
[14:19:58.109] FB13 00080000 00020000 154803CC 154803CC YES
[14:19:58.437] FB14 000A0000 00020000 154803CC 154803CC YES
[14:19:58.781] FB15 000C0000 00020000 4C8E2203 6166CEDB NO
[14:19:59.109] FB16 000E0000 00020000 18A52C21 63A4B94B NO
[14:19:59.109] kernel flash enable
[14:19:59.125] kernel blank flash page: addr: 000E0000
[14:19:59.828] rkrv: preamble 1 error
[14:19:59.828] WARNING: failed to erase page at 000E0000!
[14:19:59.828] kernel flash disable
[14:19:59.843] readback mismatch
[14:19:59.843] interface close
[14:20:05.546] 1048576 byte image read.
[14:20:13.203] Using interface OpenPort 1.3 Subaru TX4592Dm2144f6c914e91698de6c3289ea9d25d750e713e9
[14:20:14.546] kernel get version
[14:20:14.562] kernel already resident - skipping kernel load
[14:20:14.781] kernel get version
[14:20:14.781] kernel version is : OpenECU Subaru SH7058 OCP Kernel V1.05
[14:20:14.781] reading kernel comm buffer size
[14:20:14.796] comm buffer size set to 512
[14:20:14.796] reading kernel flash buffer size
[14:20:14.812] flash buffer size set to 4096
[14:20:14.812] -- flashing image to ECU memory --
[14:20:15.218] -- comparing ECU flash memory pages to image file --
[14:20:15.218] seg start len ecu CRC32 img CRC32 same?
[14:20:15.234] FB01 00000000 00001000 29450393 29450393 YES
[14:20:15.250] FB02 00001000 00001000 8F101821 8F101821 YES
[14:20:15.281] FB03 00002000 00001000 B444A26D B444A26D YES
[14:20:15.296] FB04 00003000 00001000 104341C4 104341C4 YES
[14:20:15.328] FB05 00004000 00001000 EBCDD9C9 EBCDD9C9 YES
[14:20:15.343] FB06 00005000 00001000 7E3DAFE5 7E3DAFE5 YES
[14:20:15.359] FB07 00006000 00001000 91165354 91165354 YES
[14:20:15.390] FB08 00007000 00001000 064EA404 064EA404 YES
[14:20:15.640] rkrv: bad checksum
[14:20:15.640] error reading CRC!
[14:20:15.640] interface close
[14:20:15.656] interface close
[14:20:23.093] Using interface OpenPort 1.3 Subaru TX4592Dm2144f6c914e91698de6c3289ea9d25d750e713e9
[14:20:24.437] kernel get version
[14:20:24.437] kernel already resident - skipping kernel load
[14:20:24.656] kernel get version
[14:20:24.656] kernel version is : OpenECU Subaru SH7058 OCP Kernel V1.05
[14:20:24.656] reading kernel comm buffer size
[14:20:24.671] comm buffer size set to 512
[14:20:24.671] reading kernel flash buffer size
[14:20:24.687] flash buffer size set to 4096
[14:20:24.687] -- flashing image to ECU memory --
[14:20:25.093] -- comparing ECU flash memory pages to image file --
[14:20:25.093] seg start len ecu CRC32 img CRC32 same?
[14:20:25.109] FB01 00000000 00001000 29450393 29450393 YES
[14:20:25.125] FB02 00001000 00001000 8F101821 8F101821 YES
[14:20:25.156] FB03 00002000 00001000 B444A26D B444A26D YES
[14:20:25.187] FB04 00003000 00001000 104341C4 104341C4 YES
[14:20:25.218] FB05 00004000 00001000 EBCDD9C9 EBCDD9C9 YES
[14:20:25.234] FB06 00005000 00001000 7E3DAFE5 7E3DAFE5 YES
[14:20:25.265] FB07 00006000 00001000 91165354 91165354 YES
[14:20:25.296] FB08 00007000 00001000 064EA404 064EA404 YES
[14:20:25.546] FB09 00008000 00018000 1CD5C3EF 1CD5C3EF YES
[14:20:25.890] FB10 00020000 00020000 C54810DF C54810DF YES
[14:20:26.234] FB11 00040000 00020000 9B4BE434 9B4BE434 YES
[14:20:26.578] FB12 00060000 00020000 E1B77DB7 786FE25F NO
[14:20:26.906] FB13 00080000 00020000 154803CC 154803CC YES
[14:20:27.250] FB14 000A0000 00020000 154803CC 154803CC YES
[14:20:27.578] FB15 000C0000 00020000 4C8E2203 4C8E2203 YES
[14:20:27.921] FB16 000E0000 00020000 154803CC 18A52C21 NO
[14:20:27.937] kernel flash enable
[14:20:27.937] kernel blank flash page: addr: 000E0000
[14:20:28.609] erased in 1 pulse(s)
[14:20:28.609] kernel write flash buffer addr: 000FF000 len: 00000200
[14:20:28.703] kernel write flash buffer addr: 000FF200 len: 00000200
[14:20:28.796] kernel write flash buffer addr: 000FF400 len: 00000200
[14:20:28.890] kernel write flash buffer addr: 000FF600 len: 00000200
[14:20:28.984] kernel write flash buffer addr: 000FF800 len: 00000200
[14:20:29.078] kernel write flash buffer addr: 000FFA00 len: 00000200
[14:20:29.171] kernel write flash buffer addr: 000FFC00 len: 00000200
[14:20:29.265] kernel write flash buffer addr: 000FFE00 len: 00000200
[14:20:29.359] kernel commit flash addr: 000FF000 len: 00001000 crc32 fcb948e7
[14:20:29.390] written in 1 pulse(s)
[14:20:29.406] kernel blank flash page: addr: 00060000
[14:20:31.468] erased in 1 pulse(s)
[14:20:31.484] kernel write flash buffer addr: 00060000 len: 00000200
[14:20:31.578] kernel write flash buffer addr: 00060200 len: 00000200
[14:20:31.687] kernel write flash buffer addr: 00060400 len: 00000200
[14:20:31.796] kernel write flash buffer addr: 00060600 len: 00000200
[14:20:31.906] kernel write flash buffer addr: 00060800 len: 00000200
[14:20:32.000] kernel write flash buffer addr: 00060A00 len: 00000200
[14:20:32.109] kernel write flash buffer addr: 00060C00 len: 00000200
[14:20:32.203] kernel write flash buffer addr: 00060E00 len: 00000200
[14:20:32.312] kernel commit flash addr: 00060000 len: 00001000 crc32 f3045306
[14:20:32.359] written in 1 pulse(s)
[14:21:00.437] flash correct! exiting.
[14:21:00.453] interface close
[14:21:00.468] interface close
3gsucks
Postby 3gsucks » Thu Jan 01, 2009 10:46 pm
I was also able to flash the car successfully many times after I put on the initial flash.
3gsucks
Users browsing this forum: Bing [Bot] and 25 guests
