EcuFlash press read ecu > soft hangs (freezes)...
Postby EvoXtrem » Wed Oct 15, 2008 1:30 am
I installed Ecuflash with success on new PC,
but after I select the car and press read ecu, it goes no response, EcuFlash hangs (freezes)…
No message or logs... Just process EcuFlash at 100% CPU …
What is this or what am I doing wrong? :shock:
EcuFlash Version 1.39.2152
Openport 1.3
Thanks :wink:
EvoXtrem
Postby rockjock » Wed Oct 15, 2008 8:49 am
if you're looking to read the X rom...its a no go still.
rockjock
Postby EvoXtrem » Wed Oct 15, 2008 11:45 pm
No, the problem it’s only for read rom, the prompt with list of cars, Mitsubishi cars selected, press reading and system failing… CPU 100% and not response (Win XP)...
EvoXtrem
Postby EvoXtrem » Wed Oct 22, 2008 12:30 am
After several tests, I found that the problem is recent versions of EcuFlash…
If I install the version 129 of EcuFlash, it works perfectly
Solution; Edit with 140 and Flash with the version 129 of EcuFlash...
Another solution? :roll:
EvoXtrem
