cant write into ecu!!! 2001wrx Bugeye
Postby AVIHAITOPOR » Mon Sep 29, 2008 3:11 am
2001wrx Bugeye
i can read the rom
i cant write to the ecu the new rom. i get this log
[12:29:00.484] Version 1.38.2080
[12:29:00.484] 11 memory models read.
[12:29:00.484] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[12:29:00.703] 264 ROM metadata models scanned.
[12:29:00.703] checksum module "subarudbw" loaded.
[12:29:00.703] flashing tool "wrx02" loaded.
[12:29:00.703] flashing tool "wrx04" loaded.
[12:29:00.703] flashing tool "sti04" loaded.
[12:29:00.718] flashing tool "sti05" loaded.
[12:29:00.718] flashing tool "mitsukernel" loaded.
[12:29:00.718] flashing tool "mitsukernelocp" loaded.
[12:29:00.718] flashing tool "shbootmode" loaded.
[12:29:00.718] flashing tool "shaudmode" loaded.
[12:29:00.718] flashing tool "subarucan" loaded.
[12:29:07.593] A4SE700D (295 tables) inheriting 16BITBASE (424 tables)
[12:29:07.625] 163840 byte image read.
[12:29:10.875] Using interface OpenPort 1.3 Universal TX27zcPvb1eeb4d9bbf8548033dbbb882f0e078e14e14fb6
[12:29:15.890] denso02_bootloader_cmd_start
[12:29:16.109] writing kernel area addr: 020000 len: 0664
[12:29:18.031] kernel get version
[12:29:18.046] kernel version is : OpenECU Subaru HC16 Kernel V1.05
[12:29:18.046] reading kernel comm buffer size
[12:29:18.062] comm buffer size set to 512
[12:29:18.062] reading kernel flash buffer size
[12:29:18.062] flash buffer size set to 4096
[12:29:18.062] Flashing image to ECU memory...
[12:29:18.468] comparing ECU flash memory pages to image file
[12:29:18.468] seg start len ecu CRC32 img CRC32 same?
[12:29:18.468] kernel CRC32 area: addr: 00000000 len: 00004000
[12:29:18.781] FB01 00000000 00004000 3E24E34E 3E24E34E YES
[12:29:18.781] kernel CRC32 area: addr: 00004000 len: 00004000
[12:29:19.109] FB02 00004000 00004000 68792C62 68792C62 YES
[12:29:19.109] kernel CRC32 area: addr: 00008000 len: 00004000
[12:29:19.421] FB03 00008000 00004000 04D1F50C 04D1F50C YES
[12:29:19.421] kernel CRC32 area: addr: 0000C000 len: 00004000
[12:29:19.750] FB04 0000C000 00004000 7C8DCF1E 7C8DCF1E YES
[12:29:19.750] kernel CRC32 area: addr: 00010000 len: 00004000
[12:29:20.062] FB05 00010000 00004000 DF971275 DF971275 YES
[12:29:20.062] kernel CRC32 area: addr: 00014000 len: 00004000
[12:29:20.390] FB06 00014000 00004000 5F1920BF 5F1920BF YES
[12:29:20.390] kernel CRC32 area: addr: 00018000 len: 00004000
[12:29:20.703] FB07 00018000 00004000 B9F21323 B9F21323 YES
[12:29:20.703] kernel CRC32 area: addr: 0001C000 len: 00004000
[12:29:21.031] FB08 0001C000 00004000 3C6EDF0D 3C6EDF0D YES
[12:29:21.031] kernel CRC32 area: addr: 00028000 len: 00004000
[12:29:21.343] FB09 00028000 00004000 17110B5C 8FE64004 NO
[12:29:21.343] kernel CRC32 area: addr: 0002C000 len: 00004000
[12:29:21.671] FB10 0002C000 00004000 671AA763 671AA763 YES
[12:29:21.984] reading ecu programming voltage
[12:29:21.984] programming voltage is 4.32 volts
[12:29:21.984] programming voltage is out of range!
[12:29:21.984] interface close
i need some help
read image-WRX2001-IZIK.hex
(160 KiB) Downloaded 653 times
read image2001WRX-OEM.hex
(160 KiB) Downloaded 643 times
New Text Document.txt
(2.99 KiB) Downloaded 778 times
AVIHAITOPOR
Postby absubtle » Wed Oct 22, 2008 9:06 pm
Kind of an old post. I hope you have figured out the problem already.
But, for others that may have this problem in the future.... Your programming voltage is too low. It needs to be battery voltage 11.6V+.
That usually means that you have not jumped the white 4-wire connector. It's usually hanging near the green test connectors.
Absubtle
CO
absubtle
Users browsing this forum: No registered users and 51 guests
