I doubt that will work. I don't think the key codes are stored in the ROM that we'll be reading/reflashing.canosardines wrote:Just taking the bin file from the original ECU and putting it into the new ECU will work? Is that correct? Then if i were to purchase another ECU and flash it with the bin file off my car it should work?
MalibuJack wrote:The Key codes should be different than the Immobilizer code.. Key codes are programmed in the immobilizer, the Immobilizer module is married to the ECU.. If I recall, as long as your immobilizer code is in your ECU Bin, then rewriting a new ECU with your original bin should give you a cloned ECU and should work..
Remember, the Immobilizer module lets you (the end user) add additional keys.. But you can't just replace your ECU..
Jon [in CT] wrote:The immobilizer information stored within the ECU isn't part of the ROM that we can copy. You can't yet clone your ECU so that the clone works.
Attached is a brief description of how the Subaru immobilizer works.
Users browsing this forum: No registered users and 5 guests
