Noobs Guide to Reprogramming Mitsubishi EVO 3 Factory ECU
Postby Mitsiman » Sun Aug 17, 2008 5:22 pm
I have read through the forums and picked up a lot of information, but the one thing I couldn't find was a detailed guide how to do this from start to finish.
I have downloaded the ECUFlash software and that looks fairly intuitive.
My question is mostly, other than purchasing the appropriate tuning cable, do I need to modify the ECU to be able to re flash it or can I just go straight into loading the software, copying the factory maps and then saving them, and then jumping straight into altering the maps and re flashing the ecu?
I work with after market EMS systems all the time, but this is a new area for me working within a factory ECU so I am wanting to get all the information I can.
Today I will use my Scanner to get the rom information off the ecu so I can then confirm which definiton maps etc I should be using.
Mitsiman
Re: Noobs Guide to Reprogramming Mitsubishi EVO 3 Factory EC
Postby xor » Mon Aug 18, 2008 5:49 am
I am afraid Evo 3 (1995-1996) does not have a flashable ECU. It may have an EPROM ECU or in worse case just OTP processor – one time programmable by the factory. If you are lucky and have the EPROM ECU, you can socket it and put the flash memory.
xor
Postby Mitsiman » Mon Aug 18, 2008 5:05 pm
Thanks for the tip time to look at other options
Mitsiman
Postby evonut270 » Sat Sep 27, 2008 11:56 pm
get an evo 8 4 plug ecu with appropriate harness.wire in an obd II port.
evonut270
Postby evonut270 » Sat Sep 27, 2008 11:57 pm
evonut270
Users browsing this forum: No registered users and 49 guests
